Rats
Mormonmopedmaifa
Post by Mormonmopedmaifa »
well... how would i go about finding them
M>M<M
THE MAFIA STRIKES AGAIN!!!
ALMOST running spree!!!
MySpree
Post by MySpree »
... man i have fixed carbs for atleast 10 ppl on here... or that were just scrolling thru the sites... and then mr upsmale mosyes in and takes my job... that sickens me
Mormonmopedmaifa
no offense i dont wana be a weiner but i really dont wanna hear it. i understand ur * but i just wana fix my scoot.
i got a new bystarter today froma junkyard .. and the whole reason i got it was cuase the old one only had 1 of the 3 plastic peices that hold on the brass cylinder and on the way home one of the ones on the new one broke off... the plastic is clearly just insanely old and brittle. is there any way i could just order that part (the little platic plug with the three peices on the end of it not the whole bystarter) new so it wouldnt be so brittle and break? or has neone on here found a good way to jimmy rig it so it'll work?
M>M<M
Contact Greg for those parts. He's got a ton of bystarters kicking around with no pins.
niftyfifty
Post by niftyfifty »
I'm having the exact same problem! please message me when you get it fixed so i can do the same!
just been told that the o ring seal in the oil pump can go and you can get a vacuum leak through that, so first thing tomorrow i'm going to pull my oil injector off and plug up hole and premix my fuel. anyone know what oil to fuel ratio to use?
niftyfifty wrote:I'm having the exact same problem! please message me when you get it fixed so i can do the same!
Don't do that. If the ring is shot replace it and keep running the pump.
