Sprelite The Begining Of My Epic Build
SpreeMadness520
Re: Sprelite The Begining Of My Epic Build
Post by SpreeMadness520 »
Thanks. I still need a tire and a shock, What shock did you use?
130cc Stroker
1984 Porsche 944
1965 Vespa
Petrock's 1984 Spree
Post by Petrock's 1984 Spree »
I used the 94-01 elite shock because i managed to find an engine with half a frame.
And i just relocated the shock mount right under the VR mount
P1010842 by jpetrak, on Flickr
IIRC the spree shock is about 1/4'' longer than the elite shock but it has a little different coil over. Im guessing that the elite shock is a bit stiffer because the elite is rated for a heavier rider, so the shock has to support that much more weight. All a guess though
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
SpreeMadness520
Thanks to Trafficjamz I got a jet, Bought a tire of the correct size today. Now waiting on someone with an Elite E Shock and a unifilter....
130cc Stroker
1984 Porsche 944
1965 Vespa
xxjareebxx
Post by xxjareebxx »
SpreeMadness520 wrote:Thanks to Trafficjamz I got a jet, Bought a tire of the correct size today. Now waiting on someone with an Elite E Shock and a unifilter....
look on ur fs thread i think i have one for you
1990 honda elite soon to be dio swap
looking for a dio engine anyone have one for sale?
selling a 1990 honda elite engine runs great shoot me an offer.
SpreeMadness520
New tire should be here soon, Also the honda elite E shock is on its way :happy: I need to stop by fastenal to get a m10x140mm bolt to weld for the new shock mount :geekdance: ....
130cc Stroker
1984 Porsche 944
1965 Vespa
SpreeMadness520
Ok the build is starting to move along quickly, Got the Elite E shock, M10x140mm bolt, A unifilter (thanks Kingjeff) and the tire should be here soon. I will weld the bolt to the frame monday and run gas and vacuum lines AND IM READY TO RIDE! Stock :woot:
130cc Stroker
1984 Porsche 944
1965 Vespa
SpreeMadness520 wrote:Ok the build is starting to move along quickly, Got the Elite E shock, M10x140mm bolt, A unifilter (thanks Kingjeff) and the tire should be here soon. I will weld the bolt to the frame monday and run gas and vacuum lines AND IM READY TO RIDE! Stock :woot:
I want to race you while you are still at 49cc.
It is the only time I may be able to beat you.
SpreeMadness520
MAY be able to beat me.... :wink:
130cc Stroker
1984 Porsche 944
1965 Vespa
SpreeMadness520
New tire,Shock,And bolts :2thumbs:
updates... 002.jpg (196.52 KiB) Viewed 7966 times
updates... 001.jpg (230.97 KiB) Viewed 7966 times
updates... 003.jpg (158.81 KiB) Viewed 7966 times
130cc Stroker
1984 Porsche 944
1965 Vespa
SpreeMadness520
I welded the new shock mount and the shock is like 1/8 inch from hitting the Fu@k!ng tire :evil: time to cut it off and re-weld... :bs: But i have to admit it did look Bad@ss when it was all together. Thanks kingjeff for the uni.
130cc Stroker
1984 Porsche 944
1965 Vespa
fastplastic
Post by fastplastic »
did you use any washers to space the shock out correctly?
SpreeMadness520
Yeah of course still didnt add much room, I didnt weld the bolt with enough thread. Good thing I bought 2 :smile:
130cc Stroker
1984 Porsche 944
1965 Vespa
fastplastic
if you use the drill and weld way its alot easier if you got the right size bolt :thumbwink:
SpreeMadness520
I just re welded the bolt so there is more thread to keep it away from the tire, And the weld job is SEXY :thumbwink:
130cc Stroker
1984 Porsche 944
1965 Vespa
fastplastic
hurry up only 2 more days till race day :2thumbs:
