homemade 2 stroke pipes
xxjareebxx
Post by xxjareebxx »
anyone have any tips on modifting a pipe to work for the dio? like buying some pipe and cuting and welding it to fit? would it be better to use a close as i could pipe as for as cc's go? like get a 70cc for a 70cc bore? i was thinking something like this
http://cgi.ebay.com/ebaymotors/Front-an ... ccessories
1990 honda elite soon to be dio swap
looking for a dio engine anyone have one for sale?
selling a 1990 honda elite engine runs great shoot me an offer.
Re: homemade 2 stroke pipes
EliteDio concocted such a pipe for his Dio-fitted Elite "E" and enjoyed good performance. Your're right that the lengths and tapers and diameters matter a lot for optimal performance.
While there is great satisfaction in Doing It Yourself, there is no shortage of affordable ready-made options. The Phongeer Long (PG Long) is about $150 at VT Cycles and all the engineering has been done for you if you're running a 72cc-90cc kit. Many cheaper options can be found on eBay and at JiangWayne in BC Canada.
xxjareebxx
Wheelman-111 wrote:Greetings:
yeah i seen that thread, i just think it would be neat to make it my self lol
Post by eliteguy50 »
That pipe would be too much for a 70 kit. It is designed to flow higher RPMs and almost double the displacement.
xxjareebxx
eliteguy50 wrote:That pipe would be too much for a 70 kit. It is designed to flow higher RPMs and almost double the displacement.
Yeah that's what i was saying about modifying a pipe with a close to the same bore
Yes, match the bore (displacement) and RPM range for power band. The porting and the pipe must work together for max performance.
xxjareebxx
okay thats what i was thinking to, i know its more than just that, cuz you have to know how the pipe is gona expand and stuff
There are several reference books out there on building pipes. Gordon Jennings is the first on to come to mind.
http://www.vintagesleds.com/library/man ... ndbook.pdf
wiguy05
Post by wiguy05 »
For the time and money you'll have into building your own (and most likely looking rather crappy) you will be far better off to just buy a ready made pipe. They can be found for less than $100 in good used condition.
2006 Sachs Madass
- FTP 140cc Kit
2006 Xkeleton Trickster
- Lifan 90cc auto
xxjareebxx
wiguy05 wrote:For the time and money you'll have into building your own (and most likely looking rather crappy) you will be far better off to just buy a ready made pipe. They can be found for less than $100 in good used condition.
Yeah Ik that but its just more of away to mess around a lil bit
fastplastic
Post by fastplastic »
start with a pipe that has a detachable head pipe and make your own easiest way to do it if i can find a link to the pipe i will post it
xxjareebxx wrote:okay thats what i was thinking to, i know its more than just that, cuz you have to know how the pipe is gona expand and stuff
Not if you are looking to
xxjareebxx wrote:anyone have any tips on modifting a pipe to work for the dio? like buying some pipe and cuting and welding it to fit? ...
If you are building a pipe instead of modifying a pipe, then there are calculations to be made. The math isn't as hard as it is built up to be.
maddog
Post by maddog »
if you think that you can build a better pipe than polini or malossi which are in direct competion with all there parts, go for it :surprise:
It's not always a question of building a better pipe. It's about Doing It Yourself, and getting pretty good results. There's merit in that too.
xxjareebxx
yeah i just like building stuff and working with metal
