Where can I buy a piston?
tom waite
Post by tom waite »
1984 honda aero 50. Cheapcycleparts.com has the part #s but do not carry them. They say Honda discontinued them. Any idea where I can get a replacement piston for it? The original one is chewed up to holy heck.
odinxxix
Re: Where can I buy a piston?
Post by odinxxix »
have you tried your local motorsports shop?
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
tom waite
Post by tom waite »
odinxxix wrote:have you tried your local motorsports shop?
Not yet. I work insane hours and was hoping to find one online. I never get a chance to swing by or call before close. I will try during lunch tomorrow.
tom waite
Post by tom waite »
Post by eliteguy50 »
Maybe Taz could hook you up.
You can call your local honda dealer and have them do a national search of all Honda dealers to see if there is a NOS set on a shelf somewhere.
tom waite
Post by tom waite »
eliteguy50 wrote:Maybe Taz could hook you up.
martynkim hooked me up :2thumbs:
kylebo
Post by kylebo »
I have one If it does not pan out. The latter 80's aero pistons will fit perfet but they have a dome head insted of flat top like the 84. two head gaskets could get you the right compression.
01 dio, polini 72cc, 8.4 gears, 28oko, ruima crank, PG short, ported intake, 42.3 rolls
2nd build
86 aero
10-1 secondary gears form a dio.
arisol 46mm
pg short
carb? not yet
tom waite
Post by tom waite »
kylebo wrote:I have one If it does not pan out. The latter 80's aero pistons will fit perfet but they have a dome head insted of flat top like the 84. two head gaskets could get you the right compression.
This is untrue. Early motors(83-84) have dished, 40mm piston. Later motors have a 41mm piston. I also learned that some later 41mm pistons are dished. So if you have a 40mm piston, PM me.
Tom,
If you keep striking out on an 84/83 Aero piston, one thing you might look into is the Honda Express models (PA50, PA50II and NU50). They had a 40mm bore like your model, and similar stroke:
Honda Express: 40 x 39.6
Honda Aero 83/84: 40 x 39.3
Part numbers are not exact, so there's some difference. Honda Express looks like a domed piston vs dished. If that's all, you'd be back in business. Here is a rough comparison of the Aero 50 vs PA50 piston. There is a PA50 piston on eBay, perhaps the seller can give you more info - piston pin height or any other helpful info for a possible swap.
tom waite
Post by tom waite »
mousewheels wrote:Tom,
I could kiss you.
I could kiss you.
Thanks - no need to :oops: :D
One thing helpful to all who follow your path would be to find out the piston pin dia and height of the 83/84 vs later models. If you can measure that, an idea result would be to bore out to 41mm and use an AF05 piston. That might finally give 83/84 users a 'bore kit' option, since there are some sources of +1, +2mm or more pistons for the AF05.
Thanks in advance - mousewheels
tom waite
Post by tom waite »
mousewheels wrote:
I could kiss you.
I have them both. The later model piston is considerably shorter. The pins seem to be the same size, but there would be little to no compression. I will post pictures later. I would have just bored my jug to 41mm. But that isn't happening.
All those use 10mm pins, I believe.
Other critical dimension is compression height, which is the distance from the center of the pin to the top face of the piston.
If you have two pistons with the same diameter, pin size, and compression height, they are for all intents and purposes interchangeable.
tom waite
Post by tom waite »
completely different :cry: Old chewed up one on the right(83-84) and late model on the left
maddog
Post by maddog »
you could do 2 things to that piston , 66mph back then- ahhh those were the days.
