Sprelite The Begining Of My Epic Build
- SpreeMadness520
- fastplastic
Re: Sprelite The Begining Of My Epic Build
theres a race on friday....
- SpreeMadness520
Time? I might be able to get a ride from my friend....But I do have school so idk???
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- SpreeMadness520
Ok I put the engine on with the new shock mount, It looks fantastic but it seems like the tire is off set a litte. Im still going to throw it all together and take it for a few test rides if it is messed up I will cut the mount to compensate. Hopefully the dio will be powerfull enough (stock) to pull wheelies on the little spree
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
In good tune it is unless you stretch out the engine hanger.SpreeMadness520 wrote:Ok I put the engine on with the new shock mount, It looks fantastic but it seems like the tire is off set a litte. Im still going to throw it all together and take it for a few test rides if it is messed up I will cut the mount to compensate. Hopefully the dio will be powerfull enough (stock) to pull wheelies on the little spree
- SpreeMadness520
Some update pics...
- Moped.. 004.jpg (140.53 KiB) Viewed 5153 times
- Moped.. 005.jpg (94.88 KiB) Viewed 5153 times
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- Trafficjamz
With stock gears, it will wheelie for sure
My stock 1994 elite did a 16.5 second 1/8th mile run @ 38mph
- SpreeMadness520
- Trafficjamz
I have some 2k grabs you can have......that should do the trick.SpreeMadness520 wrote:How large?
- SpreeMadness520
how much you want for em?
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- Trafficjamz
SpreeMadness520 wrote:how much you want for em?
Trafficjamz wrote:I have some 2k grabs you can have......that should do the trick.
- SpreeMadness520
Thanks man
, Is superman 2 ready for tomorrow?
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- Trafficjamz
Will your spree be ready for tomorrow?SpreeMadness520 wrote:Thanks man, Is superman 2 ready for tomorrow?
My 86cc will be ready to go.
The 125cc will not be ready
Maybe next week.
- SpreeMadness520
Im thinking not, Didnt have any time to start it tonight so I dont even know if the wiring is correct, Plus my dad will have no time when he gets home so its straight to the track.....
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- SpreeMadness520
Oh I forgot to mention, don't forget to smooth out all of the sharp edges on the 125cc, I don't want to slice a hole into another dimension when I'm setting the track record...LMFAO
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
