stock carb pilot mod WORKS!
kylebo
Post by kylebo »
I finally got to try my pilot mod. My testing has been with a stock carb and intake with a K&N stile filter and malossi carbon reeds. Matched up to a 47mm Taiwan PG bore on a AF16
I ran the motor in for 30 miles with the pilot jet drilled out to the .50 bit. I could tell it was way rich on the bottom but seemed great for a mellow breakinn. To adjust it leaner I simply pulled the pilot back out of the carb and pinched it with a vice grips where the pick up tube meets the press in flange. I pinched it twice on 90 deg., like a square to smosh the pilot hole smaller. I instaled it and got very lucky it is spot on the right size with no heat spike what so ever and throttle snap like you would not believe a stock carb could give. This opens up a world of possibilities for the stock carb on big bore's
I have the carb air bypass set at 2 1/2 out I would be glad to help anyone out that would like to try this mod for themselves.
01 dio, polini 72cc, 8.4 gears, 28oko, ruima crank, PG short, ported intake, 42.3 rolls
2nd build
86 aero
10-1 secondary gears form a dio.
arisol 46mm
pg short
carb? not yet
kylebo
Re: stock carb pilot mod WORKS!
Post by kylebo »
I did the rest of the tuning today and it is running perfect. I have the clip at the top Leanest setting and the main jet is drilled out with a bit that will not fit in a oko 120 but will slide it a 125. So I am running a 122 main I would guess with the pilot mod, and clip in the top with a k&n. I ran for over 1 mile full throttle with a max temp of 335. No heat spike after throttle released promptly after 1 mile run. Running high 40's with 10;1 gears.
see it in advanced tech docs (kylebo mods pilot)
2nd build
86 aero
arisol 46mm
pg short
carb? not yet
