A few technical problems...
Bleroy
Post by Bleroy »
I have a few problems with my 85' spree.... One is that when you turn it on, the headlight doesn't come on like usual. The second is when I turn on the turn signal, it stays lit, no blinking. And one question, is the speedometer (dash) supposed to light up also? I have never seen it physically in the dark, so I'm not sure if it is supposed to. Thanks for the help! :newb: :2thumbs:
85' Honda Spree (Work in progress)
frenchiehxc
Re: A few technical problems...
Post by frenchiehxc »
sounds to me like a bad battery.. maybe a problem in your electrical? i had the same problem with mine i had to hook a duracell portable pack to it until i got the new battery. lol theyre roughly cheap.. try charging it first. remember that new batterys dont come fully charged
85' Spree
Yamaha Razz
High Rev CDI
Un-Governed
Yamaha YT125 Tri-Moto
BBK
Fatboy exhaust
cool head
Bleroy
Post by Bleroy »
Yeah but I JUST bought a battery, so I don't think that is it. And I fully charged it. So maybe electricals... And what about the dash/speedometer?
Bleroy
Post by Bleroy »
UPDATE: Just tested it with another battery, and same thing happened, so no go on the bad battery.
The head light and dash lights are AC driven by the alternator and only work when the engine is running.
killerpancake
Post by killerpancake »
turn signals will come on and stay on if you have 1)a bad bulb 2)bad flasher unit.
If it don't fit, force it. If it breaks, it needed to be replaced anyway.
(Previous)
87 honda spree
85 honda spree
(Current)
88 yammy razz
(parts bike)
another 88 yammy razz
woodman
Post by woodman »
i had a pinched wire where the plastic tail light attached to the rack that caused the same issue. not sayin its your problem but worth checkin.
