gonna c4 my spree
gonna c4 my spree
ok im ready to stick some c4 in this spree and blow it to the moon lol.got my carb clean and now it runs good except it wont idle very good and wont run with the air box lid on,so its running way to rich i would think.so i leaned out the throttle needle tried leaning out the fuel mixture jet no help.when u put the air box top on and hit the gas it just barley goes.also this thing used a whole tank of gas in about an hour of riding!!!!and its not leaking anywhere
Re: gonna c4 my spree
What size is the main jet? Any chance a larger one was swapped in (it should be a #68)?
1986 Spree w/ '87 SE50 motor
Looking further down the list of posts I saw this:
http://www.hondaspree.net/phpBB3/viewto ... =3&t=19003
You probably used too large of a bit and thats why your running rich at idle.
If thats the case you don't have many options. One forum member has had luck leaning out a modded idle jet by pinching the tube twice with a 90* angle between the pinches.
His post here:
http://www.hondaspree.net/phpBB3/viewto ... =1&t=18974
If you have a parts carb around you can swap the idle jets between them, its a little tricky but not hard if you take your time and are careful.
Or you can replace the entire carb and keep your current one for parts (what I did when I first started working on these a few years back and made the same mistake).
His post here:
Awesome. You drilled out your idle jet? If so, that carb's now a paperweight.
No wonder it's running rich. Time to buy another carb.
Admin, Hondaspree.net
ur right on the money ordered a new carb.oh well live and learn dumba__ move on my part.i wondered why it used a tank of gas in no time.
extraslimcase
Hey... at least now you can save the c4 for something else.
