99 Elite S De-Restriction
godfella691981
Post by godfella691981 »
Hello, I was wondering does a 99 elite have the same restrictions as the other years? The only ones I know of are the plate that needs to be removed from the variator and then the muffler has the washer in the tip? Are those the only two restrictions on these?
<br>
<br>
:peace:
Re: 99 Elite S De-Restriction
The airbox inlet may be different - one of 2 holes blocked. Once deristricted, it is very important that you check your carb's main jet. Nothing smaller than 78 should be used at WOT. You may also wish to consider wiring the "throttle" lever on the oil pump so it runs wide open.
godfella691981
I had a 94 Elite S once before and I removed the variator restrictor, and I got right at 40mph out of it. And I never opened that oil pump and had it for well over a year..
My airbox didnt have any restrictions in it though, unless I was looking in the wrong place
metric
Post by metric »
Got the same bike same color to the restriction is in VAR and pipe. I got mine doing close to 70mph on a slite hill with a polini 72 kit, polini gears, LeoVince hand made ZX pipe they dont make them anymore either, and stock carb running 110 race gas mixed
odinxxix
Post by odinxxix »
the stock elite S has a 68 main jet, the stock elite SR has a 78 main jet, of course mine has the second hole opened up on the air box and im running an 85 main jet. and if you dont buy a split throttle cable then you will need to zip tie your oil pump open
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
SpreeMadness520
Post by SpreeMadness520 »
Nice variator+9:1 gears+Unrestriced pipe=50mph AT LEAST
130cc Stroker
1984 Porsche 944
1965 Vespa
odinxxix
Post by odinxxix »
thats what my set up is but i have 7.5gram rollers.
break down:
2000 elite S
2nd hole in airbox opened, 85 main jet
prodigy variator/7.5 gram rollers
9:1 secondary gears
unrestricted stock pipe
and stock bore.
runs quick to 35-40 then steady climb to 45-50. i have not gps'd so real top speed is unknow those are just guesses
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
SpreeMadness520
Im probably going to run that on my spreedio for a while. :geekdance:
130cc Stroker
1984 Porsche 944
1965 Vespa
