Checkin in, first post... here at least
Re: Checkin in, first post... here at least
Chicago Ben wrote:
Wheelman-111 wrote:Greetings:
Very nice! I hope I'm wrong, but will now predict the JBWeld stuff won't adhere to the ABS plastic for long. At least you heard it here first, and it's not going to matter much if using the stock tail-lamp. :wink:
You know, I'm sure you have seen some videos from "DIOSPEEDDEMON" on youtube, he has literally hundreds of honda elite videos - how tos and what not
He used jb weld... I decided to try it... I cannot imagine this stuff cracking or going anywhere, it dries to an extremely hard state. I was going to pickup a jap rear tail light off ebay from daywot one of these days
Haven't use JB Weld much have you? It does not work well where extreme temp ranges, flexing and/or stress are involved.
Chicago Ben
Post by Chicago Ben »
Bear45-70 wrote:Haven't use JB Weld much have you? It does not work well where extreme temp ranges, flexing and/or stress are involved.
damnit, thought it would be better than slapping on body filler.
I'm just going to do it this way and if I have to go back and redo it next year then whatever
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
1000k Polini triples
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
look what the man in brown brought today
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Very nice :thumbwink:
I pressed your 8.4:1 gears on today too I will post pics tomorrow :wink:
Hey BTW post up a pic of your exhaust......I want to see what a typhoon pipe looks like.
Chicago Ben
Trafficjamz wrote:I pressed your 8.4:1 gears on today too I will post pics tomorrow :wink:
booya
here is that exhaust:
Dont tell me I need a PG Long haha
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
how many sections is it? 10 or 13 I can't tell from your picture. :confused:
killerpancake
Post by killerpancake »
this project is still in progress!? :smile:
If it don't fit, force it. If it breaks, it needed to be replaced anyway.
(Previous)
87 honda spree
85 honda spree
(Current)
88 yammy razz
(parts bike)
another 88 yammy razz
fastplastic
Post by fastplastic »
booya
Chicago Ben
fastplastic wrote: :*:
what are you *'ing? the exhaust?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
Traffic-
here is a picture of the typhoon again
looks like 10 "sections"
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Post by eliteguy50 »
Trafficjamz-A trusted Hawaii member once told me that the PG sectional, V8 sectional, Typhoon are all the same Taiwan pipe with different badges.
eliteguy50 wrote:Trafficjamz-A trusted Hawaii member once told me that the PG sectional, V8 sectional, Typhoon are all the same Taiwan pipe with different badges.
Then what pipe is this?
fastplastic
all these exhausts are so close looking and just found another one that looks like mine but different name.....
Chicago Ben
as eliteguy50 stated, its apparent that this exhaust is just badged different ways
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
The what pipe is this?
Looks like teh R1 that Patrick used to sell. 13 sections like the Yosh but it has a solid support.
