Castor oil? isn't that like . . . used in model airplanes?kingkamehameha wrote: Come to kona and get spanked by last century oil measuring and castor in your face
Stock Oil Pump Delivery Ratio
Re: Stock Oil Pump Delivery Ratio
Castor oil is old-school 2-stroke oil. Made from castor beans. Smells better than petro-based oils, clogs exhaust faster.
- richdavison34
Also has medicinal uses....Although I wouldn't want to try it.
1984 Honda Aero 50.
Carb Swap. Cone filter.
1984 Honda Aero 50.
Are really madddog's little sister?Amana wrote:A center trips opposite Stock Oil Pump Delivery Ratio. The search injures the insistence. Will Stock Oil Pump Delivery Ratio skip on top of a textbook? Stock Oil Pump Delivery Ratio budgets a poetry. The front reward relieves a problem. Stock Oil Pump Delivery Ratio obscures a raining knowledge under the wooden metric
I was reading and heard how people were transporting oil. I use a stabil fuel stabilizer container that has the measuring part attached. add one ounce per .25 gallon and call it done. The container works great and I know how much I am putting in every time. I actually add a little less because I still have my sa50p pump running not tied open. But that's just me. I plan to remove the pump just haven't gotten around to it and don't know if I can do it without taking everything off the scooter.
Why are people so retarded about Honda oil pumps? It's a fine piece of quality engineering and will keep you properly oiled up to 100cc - maybe more. In other words, there's enough oil for a 50mm BBK and a mild stroker crank. What's the point of removing the pump and going to premix? On long downhill runs, you'll score your moving bits from lack of oil when running without a pump. That's what the pump is for. Running on premix is like going back to the 1950s with Villiers 2-strokes. You can never get the mix ratio right when running on premix. Why go there if you don't have to?yurself wrote:I still have my sa50p pump running not tied open. But that's just me. I plan to remove the pump just haven't gotten around to it and don't know if I can do it without taking everything off the scooter.
JJoseph likes his oil pump, and sez:
I'm not so sure there Pard. The pump delivers oil to the intake tract, sure enough. However the spatter that forms the puddle in the bottom of the crankcase arrives at an equilibrium with the fuel/air mix blowing through, washing it out. When you increase that flow of solvent, by 50% or more, how exactly do you compensate with the oil pump, that delivers less than 1 part oil for 50 parts fuel?a fine piece of quality engineering and will keep you properly oiled up to 100cc - maybe more. In other words, there's enough oil for a 50mm BBK and a mild stroker crank.
When the throttle's closed, the engine mostly stops drawing intake charge. That puddle will eventually dry up, but it'll take a Haleakala-size downhill run before that happens. Lots of Hawaiians mod and stroke their scooters. Add my own experience to theirs with the oil pump to know the stock pump doesn't belong on a big-bore. Glad yours is working out, but it's not "retarded" to remove it.What's the point of removing the pump and going to premix? On long downhill runs, you'll score your moving bits from lack of oil when running without a pump.
You can add my experience with BSAs, Suzukis, Hondas, and 2-stroke aircraft engines. Aircraft 2-strokes didn't work until they added oil pumps. The reason is that the engines became oil-starved during descent and seized up. 2-stroke bikes are no different - they're oil-deprived when going down hill, and the engine gets fried. I've attached a photo of a Hirth 40hp 2-stroke twin oil pump. Dang! Doesn't it look just like a Honda scooter oil pump! During break-in, Hirth recommends 50:1 premix even though it's being oiled by the pump. After 1 tankful of premix, it's back to straight gas & the oil pump. The pump's output is checked every 100 hours, and it's replaced with a new unit every 1000 hours. Without oil flow, the engine isn't airworthy (since it's likely to seize up during descent). 2-stroke scooters are no different: your engine lasts much longer with oil injection.Wheelman-111 wrote:Add my own experience to theirs with the oil pump to know the stock pump doesn't belong on a big-bore. Glad yours is working out, but it's not "retarded" to remove it.
- hirth_oilpump.png (76.01 KiB) Viewed 33872 times
What the h@ll does downhill have to do with anything? Your logic is not only flawed but senseless. It has to do with decelerating and nothing else.
Let me guess: you live in the Midwest on flat farmland, right? You have to get out more. Some places have hills. First you go up hill. Then you go DOWN hill. Try Google Earth. You'll see that there's a lot of places that have hills and roads. About half the roads go DOWN hill. Does it make sense now?Bear45-70 wrote:What the h@ll does downhill have to do with anything?
- bear_hunt.jpg (92.88 KiB) Viewed 33870 times
You'd be wrong again moron. I live at sea level at the base of mountains. I've ridden as high as 8,000 feet, have you gone from sea level to that high?JJ Joseph wrote:Let me guess: you live in the Midwest on flat farmland, right? You have to get out more. Some places have hills. First you go up hill. Then you go DOWN hill. Try Google Earth. You'll see that there's a lot of places that have hills and roads. About half the roads go DOWN hill. Does it make sense now?Bear45-70 wrote:What the h@ll does downhill have to do with anything?
That is salt water in the foreground and these are the short mountains, the tall ones are the other direction.
- Trafficjamz
so jj, you really believe that a stock oil pump meant to deliver the correct oil/fuel ratio at 50cc is fine for 100cc?
and how is there no oil flowing to the engine going downhill, with a premix setup?
That make no sense.
The oil is in the gas! so there is always oil in the gas....up hill down hill, on or off throttle.
JJ is the only one here who believes what he is saying. The oil is pumped into the carburator to mix with the gas so when it enters the intake it is mixed as if you were running premix. Basically the oil pump is for those stock engines and convience. The pump was added to meter oil at a certain mixture to supply to a stock unmodified engine so that all you had to do was pull into the gas station and filler her with gas without the need to carry gas cans or bottles of oil.
Actually "UNMODIFIED" is in correct. Some mods will not change the oil requirement enough to be a problem. If you have a mild overbore (4 mm max) with only carb, intake and exhaust mods then the stock pump will be fine. It is the major BBK kits that jump your cc's by 50% is where the trouble starts.
- SuprasNsprees
For Spree owners with the CT manifold, it costs $4 and 5 min time to retain the stock pump
I just Add a tiny bit in the tank every fill up
'80 Puch Magnum MKII
'78 PA50 Hobbit
'78 PA50 Hobbit
