Bolt On Spree-Dio swap Shock Mount SLOPE DISTANCE TESTER....
- spree-rider
Re: Bolt On Spree-Dio swap Shock Mount SLOPE DISTANCE TESTER
grab bar=super easy to fab and lots will sell on ebay. everybody wants one but they've gottens o expensive. and it dont take super strong metal to make one.
86 spree
sb 50 intake and reeds
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
high compression head
chrome low windshield
mountain bar
Xtra-10
I ALWAYS KEEP ONE ROLLED
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
mountain bar
Xtra-10
- richdavison34
Thanks for the advice spree-rider.grab bar=super easy to fab and lots will sell on ebay. everybody wants one but they've gottens o expensive. and it dont take super strong metal to make one.
If I had the stock luggage rack, I could use those mounting points as a guide. Maybe I can pick up a cheap luggage rack off eBay.
1984 Honda Aero 50.
Carb Swap. Cone filter.
1984 Honda Aero 50.
- fightingplankton
what do you have on your aero right now?
'86 spree
'86 aero50
'83 aero80
'86 aero50
'83 aero80
- richdavison34
Unfortunately, there isn't much made for it as far as performance parts go.
So far, I just have the cone air filter installed. Most of my work has been restoration....new stator, brake lines, etc.
I'd like to mount some foot pegs for it eventually.
Also, I'm planning on getting the variator test kit from Daywot, and experimenting with some different weights. Also going to get a performance clutch and hope that it's compatible...the OEM one has been discontinued.
1984 Honda Aero 50.
1984 Honda Aero 50.
- fightingplankton
i just meant..if you dont have the stock luggage rack...where is your brake light mounted
edit: nm, i just realized you meant "if i had the stock elite luggage rack, i could use that for reference points"
might as well fab one for the aero, jon said he'd like one, i may also be interested depending on function/cost/appearance.
'86 spree
'86 aero50
'83 aero80
'86 aero50
'83 aero80
- richdavison34
Will your aero mounting points be the same as mine since our year models are different?
1984 Honda Aero 50.
1984 Honda Aero 50.
- KingJeff801
richdavison34 wrote:Thanks for the advice spree-rider.grab bar=super easy to fab and lots will sell on ebay. everybody wants one but they've gottens o expensive. and it dont take super strong metal to make one.
I have a Elite S stock luggage rack if you want it........if you made grab bars like the one in my picture you would sell lots, especially if they were affordable
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Wrong Side Kings 4 Life
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
- richdavison34
PM Sent
1984 Honda Aero 50.
1984 Honda Aero 50.
i have a luggage rack for the 87 elite.
CH80
The rear profile of the later '85-on Aeros is very different from your '84. Some would say the early ones look sleeker.
For that reason, I'm inclined to beloeve the rack mount points will be quite different.
Make us some functional sidestands, Oh Please?
- spree-rider
86 spree
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
mountain bar
Xtra-10
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
mountain bar
Xtra-10
- richdavison34
PM Sent.bigluelok wrote:i have a luggage rack for the 87 elite.
I definitely agree with you Wheelman. I absolutely love my 84', but it's a total PITA trying to get parts for it since it's so different from the later models.Wheelman-111 wrote:Greetings:
I will definitely look into the side stand design. I'll make something non-invasive and bolt on, cost will be $50 or less. As I'm doing with the shock mount, I'll also do with my other items. The first one goes out for just the cost of materials to make sure it is as advertised.
How do you guys feel about some foot pegs? Some that would stick out beyond the foot board. Prob use the kind that can fold up.
That's a good deal for 6 bucks. I could definitely design a reliable bolt on mounting system for that.spree-rider wrote:These http://www.monsterscooterparts.com/kick ... i-400.html
I'll probably order one of those tonight to give myself a basis to work from this weekend.
1984 Honda Aero 50.
1984 Honda Aero 50.
I have a mostly there rack off an '85 Aero i would be willing to part with. The front mount points are broken, but enough of one is there to get a measurement.
I don't have any use for it as its already off as I'm converting to Euro-tail setup.
1986 Spree w/ '87 SE50 motor
- richdavison34
Side stand Ordered.
1984 Honda Aero 50.
1984 Honda Aero 50.
- richdavison34
devenex wrote:I have a mostly there rack off an '85 Aero i would be willing to part with. The front mount points are broken, but enough of one is there to get a measurement.
PM Sent
1984 Honda Aero 50.
1984 Honda Aero 50.
