aero 1984 almost finish
this is my bike
nb50m 1984 ab07 engine
malossi big bore kit 70cc 47.00mm
malossi variator 6 grams
doppler s3r exhaust modified by me!!
malossi cdi unit
doppler air booster box
doppler air filter
doppler air shock absorber
rpm gage
rms brake pad
rms clutch bell
polini speed clutch 3g standard
malossi yellow spring
malossi 19mm carburetor with choke cable (dellortho but they put there name on the box?)
inlation pending:
michelin 3.00 tire next week
and if you see my air ventilation not install its because i dont have the bbk yet because it in shipping and i receive it tomorrow ,can i sleep??
malossi cdi unit
doppler air filter
rpm gage
rms brake pad
rms clutch bell
inlation pending:
- IMG_0957.JPG (163.7 KiB) Viewed 11292 times
- IMG_0956.JPG (161.11 KiB) Viewed 11292 times
- IMG_0955.JPG (171.16 KiB) Viewed 11292 times
nb50m 1984
bbk malossi fonte 70cc 47.0mm
nh80 reed and intake
variator malossi multivar mhr
7.5 roller
cdi unit
RMS clutch bell
exhaust doppler s3r
booster doppler
air filter doppler
shock absorber doppler racing
michelin 3.00
7.5 roller
cdi unit
RMS clutch bell
exhaust doppler s3r
booster doppler
air filter doppler
michelin 3.00
Re: aero 1984 almost finish
this is other pics
- IMG_0958.JPG (194.28 KiB) Viewed 11291 times
- IMG_0962.JPG (149.91 KiB) Viewed 11291 times
nb50m 1984
7.5 roller
cdi unit
RMS clutch bell
exhaust doppler s3r
booster doppler
air filter doppler
michelin 3.00
7.5 roller
cdi unit
RMS clutch bell
exhaust doppler s3r
booster doppler
air filter doppler
michelin 3.00
Nice, but why did you waste your money on the CDI? It improves nothing over the stock CDI.
i know i read you relate that but i was to late ... but i will know next time
nb50m 1984
7.5 roller
cdi unit
RMS clutch bell
exhaust doppler s3r
booster doppler
air filter doppler
michelin 3.00
7.5 roller
cdi unit
RMS clutch bell
exhaust doppler s3r
booster doppler
air filter doppler
michelin 3.00
That's quite a side cover!
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- richdavison34
She is gorgeous. Where did find all these parts that are compatible with the 84' AB07? I have the same motor, but I have never heard of Maloosi making a big bore kit for it.
1984 Honda Aero 50.
Carb Swap. Cone filter.
1984 Honda Aero 50.
ask the seller at http://www.50cc.eu or wait for a bbk that i will receive tomorow or aftertomorrow i buy 2 kit so iwill have an extra one the seller told me that fit but if not i will get the 2 cylinder to a machinist for fitting! and the price is $120 a good price i think. so if interest let me know.
for the variator same thing i take the nb50 85 malossi and i cut the pulley boss at a machinist for $20 and that fit well and also i buy the zuma front pulley and that fit with the right washer that you insert in the front where the bolt is. sorry but if you want to know everything let me know what and i will post pics of how to do that!
nb50m 1984
7.5 roller
cdi unit
RMS clutch bell
exhaust doppler s3r
booster doppler
air filter doppler
michelin 3.00
7.5 roller
cdi unit
RMS clutch bell
exhaust doppler s3r
booster doppler
air filter doppler
michelin 3.00
Superbe et unique. Excellent!
(See, you Forumistas didn't know you could read French, did you?)
thanks but dont give me all the glory this forum and its great people help a lot!!
nb50m 1984
7.5 roller
cdi unit
RMS clutch bell
exhaust doppler s3r
booster doppler
air filter doppler
michelin 3.00
7.5 roller
cdi unit
RMS clutch bell
exhaust doppler s3r
booster doppler
air filter doppler
michelin 3.00
Like your build , give you very high marks in most categories......the one thing that makes me turn away is all that black plastic wire loom.....destroys the details of everything else......but with all bodywork in place, so what?
- fastplastic
also nb50 me is call melody in europe and its not nb50 its nd50 and that its just for ab07e engine.
nb50m 1984
7.5 roller
cdi unit
RMS clutch bell
exhaust doppler s3r
booster doppler
air filter doppler
michelin 3.00
7.5 roller
cdi unit
RMS clutch bell
exhaust doppler s3r
booster doppler
air filter doppler
michelin 3.00
- fastplastic
the dio engine is a lot of fun though if you ever do decided to swap
I tried to look at this site. Can you confirm the address. I am rebuilding an 83 and would like to see what parts he might have.mtully27 wrote:ask the seller at http://www.50cc.eu or wait for a bbk that i will receive tomorow or aftertomorrow i buy 2 kit so iwill have an extra one the seller told me that fit but if not i will get the 2 cylinder to a machinist for fitting! and the price is $120 a good price i think. so if interest let me know.
for the most part im going to call bs. i just happened to click on a random pass date page and saw this thread.
that cant be an ab07 engine. they do not make those parts and this guy just fell off the earth
i might just be jealous because i do want to do this to my aero soooooooooooooooooooooo bad.
