HondaBond will resist fuel. It seals the crankcases on AF16Es. Yamabond works too, but might turn into blood if used in a Honda engine.
Cheap Oil Plug
Re: Cheap Oil Plug
Re: Cheap Oil Plug
Maybe it will turn into spiders and scurry away under the garage doorWheelman-111 wrote:Greetings:
It's official! I'm addicted
Re: Cheap Oil Plug
Oops, forgot the pressure test part. read what he did with the oil pump and got concerned he might try and run it that way. SorryBear45-70 wrote:You obviously have no clue about what he is doing.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
arreche air filter
v8 pipe
stock gears
Re: Cheap Oil Plug
I actually heard diospeeddemon say to loop them together in some video on youtube. Not sure it would be a problem. Then again I don't know that much. Wouldnt the pump just recirculate oil that randomly makes its way up to it?Bear45-70 wrote:You obviously have no clue about what he is doing.dun rite wrote:Hello:
doesn't the oil pump need to be lubricated? hate to see it come apart inside the case. Check with the more knowledgable people here on the forum to be sure..Bear45-70 wrote: Put stock pump in with inlet and outlet attached together with hose.
Oh and where the * did I ever say to loop the output to the oil inlet? Never said that because I don't believe that is a safe or a smart move.
Re: Cheap Oil Plug
And that oil gets hotter and hotter because there is no fresh supply of cool oil from the tank. Not a good thing to my "reliability is everything" mind.Bugaboo wrote: I actually heard diospeeddemon say to loop them together in some video on youtube. Not sure it would be a problem. Then again I don't know that much. Wouldnt the pump just recirculate oil that randomly makes its way up to it?
Re: Cheap Oil Plug
Run a long bit of line and/or an "Oil Pump Cooler".
Some oil in circulation is better than none, but why not just remove the pump shaft or bite the bullet and put in a proper plug?
Re: Cheap Oil Plug
I agree, for $10 + shipping it is penny wise but dollar stupid not to use one.Wheelman-111 wrote:Greetings:
Run a long bit of line and/or an "Oil Pump Cooler".![]()
Re: Cheap Oil Plug
Yeah Yeah I know. Just though the looped hose is a good idea. Wouldn't it be like lubricating the transmission? That oil stays in there for a long time. Could use a heavier oil.
Re: Cheap Oil Plug
Yes, but the transmission has an oil cooler in the line which is very important. Install an oil cooler and you will be golden, no cooler and you risk a seized pump which is gonna raise * in the crankcase.Bugaboo wrote:Yeah Yeah I know. Just though the looped hose is a good idea. Wouldn't it be like lubricating the transmission? That oil stays in there for a long time. Could use a heavier oil.
- fastplastic
Re: Cheap Oil Plug
15.50 for the good plug
