Fill in by-starter hole
toad772
Post by toad772 »
Well my by starter is completely screwed It has no wires on it and it is busted all to * so I want to remove it and fill in the hole. So how do you think I should do it?
PS3 it only does everything.
richdavison34
Re: Fill in by-starter hole
Post by richdavison34 »
Buying a new one may be your safest...and ultimately cheapest....alternative. :imo:
1984 Honda Aero 50.
Carb Swap. Cone filter.
odinxxix
Post by odinxxix »
if you fill in the hole just how is it going to run while its warming up? think id find a new or used one. or you could get a manual choke like bear has.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
toad772
Post by toad772 »
odinxxix wrote:if you fill in the hole just how is it going to run while its warming up? think id find a new or used one. or you could get a manual choke like bear has.
Has ran fine with it just stuck extended all the time.
KillinSpree
Post by KillinSpree »
Brand new on ebay for $35 or pm *mopedmark* and he'll hook you up. Super fast shipping too :thumbwink:
1984 Honda Spree White
1987 Honda Spree Blue
toad772
Post by toad772 »
The scooter is only gonna be used in the woods but I will check ebay
My manual choke system only works on the Aero 80 (1983 thru 1985) and a couple of earlier model scooters that had the heat control vacuum bystarter. Oh and bystarter is one word, not two.
toad772
Post by toad772 »
Well I filled both ends in. Haven't tested it yet because I am too lazy to put the air box back together and bolt the carb back on.
toad772
Post by toad772 »
Runs perfect without the Bystarter on there and isn't all that hard to start(5 kicks)
dun rite
Post by dun rite »
Hello: what did you fill the holes with?
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
toad772
Post by toad772 »
dun rite wrote:Hello: what did you fill the holes with?
The bottom end I drove a nail into it a bit then cut it off flush with my scroll saw and the top part were the by starter goes I put the needle in and filled the hole with rtv silicone gasket maker(Both holes could be unplugged if I ever wanted to buy a new bystarter)
Well nice job, you have RUINED the carb because now another bystarter will not work on it. :jack:
Well it's off to the Home Depot to pick up a box of 16 sinkers........I'll fix that d*** bystarter.......then I'm gonna ride out to the woods and irritate a bear with my pea-shooter......I'm pretty sure that will do it...........
toad772
Post by toad772 »
Well I could unplug it not gonna though because it works fine without a bystarter.
