Chinese trouble
mr pibbs
Chinese trouble
Post by mr pibbs »
I've got a scooter that is killing me.
Came to me with 4.5 miles on it. Died while running. I got it running for a bit, but now it wont stay running unless it is wide open and even then it is just barely getting by.
New gas
clean carb
stong spark
stady flow from tank
good compression
4 stroke
Any ideas?
1993 Elite - The Mad Max
turtle13
Re: Chinese trouble
Post by turtle13 »
If it's got good compression, my first thought would be that its got an air leak somewhere.
'62 125cc Honda cub
Re: Chinese trouble
Did you check the valve clearances?
CaptainDudeMan
Re: Chinese trouble
Post by CaptainDudeMan »
Clean the carburetor change fuel lines & vacuum lines. The chinese fuel lines are crap they break down and gum up the jets in the carb. Check the vales gap they should be set at IN: 0.05mm EX: 0.05mm. I would also change the spark plug if its still the chinese one. If you need any more info for chinese scooters go to these sites
http://scootdawg.proboards.com/index.cgi
http://chinesescoots.forumwise.com/foru ... esescoots
richdavison34
Re: Chinese trouble
Post by richdavison34 »
I wish you the best of luck. The parts on those things are unbelievably cheap, and this issue might end up being more trouble than it's worth.
Sorry to be a Debbie-Downer, but I really despise anything Chinese.
1984 Honda Aero 50.
Carb Swap. Cone filter.
mr pibbs
Re: Chinese trouble
Post by mr pibbs »
Still a problem... I think it is the CDI...
New vac/fuel lines
valve clearance set
new plug again
tested with another coil
I thought i had it sussed - ran up and down the road well, but then the symptoms appeared again - i think the plug is getting fouled with carbon.
Spark is there but seems more white than blue.
Weak spark not burning everything? What do you think?
wiguy05
Re: Chinese trouble
Post by wiguy05 »
I would suspect an air leak. I had a China scoot that I tried to get going before I ended up parting it out.....check the intake elbow for any dryness/cracks.
EDIT: Also check that the vacuum diaphragm thing on top of the carb is seated and sealing correctly! This thing drove me crazy until I decided to junk it out :twisted:
PART #14 IN THE DIAGRAM
2006 Sachs Madass
- FTP 140cc Kit
2006 Xkeleton Trickster
- Lifan 90cc auto
mr pibbs
Re: Chinese trouble
Post by mr pibbs »
But why would an air leak cause a jet black carbon fouled spark plug?
CaptainDudeMan
Re: Chinese trouble
It sounds like your running rich. Is your spark plug gap set at 0.028"? black indicates a too rich fuel mixture and very light beige to white usually indicates a too lean of fuel mixture. Have you messed with the air/fuel mixture on your carburetor?
Re: Chinese trouble
+1. Carbon fouling sounds more like rich than lean.
Have you pulled apart the carb to check? Could be something silly, like a loose main jet or jammed CV slide.
mr pibbs
Re: Chinese trouble
Post by mr pibbs »
Needle seat...
Re: Chinese trouble
That will do it. A lot of reports I read on issues with Chinese motors are silly things missed in assembly... that or inferior fasteners.
