Fill in by-starter hole
Well my by starter is completely screwed It has no wires on it and it is busted all to * so I want to remove it and fill in the hole. So how do you think I should do it?
PS3 it only does everything.
- richdavison34
Re: Fill in by-starter hole
Buying a new one may be your safest...and ultimately cheapest....alternative.
1984 Honda Aero 50.
Carb Swap. Cone filter.
1984 Honda Aero 50.
if you fill in the hole just how is it going to run while its warming up? think id find a new or used one. or you could get a manual choke like bear has.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
Has ran fine with it just stuck extended all the time.odinxxix wrote:if you fill in the hole just how is it going to run while its warming up? think id find a new or used one. or you could get a manual choke like bear has.
- KillinSpree
Brand new on ebay for $35 or pm *mopedmark* and he'll hook you up. Super fast shipping too
1984 Honda Spree White
1987 Honda Spree Blue
The scooter is only gonna be used in the woods but I will check ebay
My manual choke system only works on the Aero 80 (1983 thru 1985) and a couple of earlier model scooters that had the heat control vacuum bystarter. Oh and bystarter is one word, not two.
Well I filled both ends in. Haven't tested it yet because I am too lazy to put the air box back together and bolt the carb back on.
Runs perfect without the Bystarter on there and isn't all that hard to start(5 kicks)
Hello: what did you fill the holes with?
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
arreche air filter
v8 pipe
stock gears
The bottom end I drove a nail into it a bit then cut it off flush with my scroll saw and the top part were the by starter goes I put the needle in and filled the hole with rtv silicone gasket maker(Both holes could be unplugged if I ever wanted to buy a new bystarter)dun rite wrote:Hello: what did you fill the holes with?
Well nice job, you have RUINED the carb because now another bystarter will not work on it.toad772 wrote:The bottom end I drove a nail into it a bit then cut it off flush with my scroll saw and the top part were the by starter goes I put the needle in and filled the hole with rtv silicone gasket maker(Both holes could be unplugged if I ever wanted to buy a new bystarter)dun rite wrote:Hello: what did you fill the holes with?
Well it's off to the Home Depot to pick up a box of 16 sinkers........I'll fix that d*** bystarter.......then I'm gonna ride out to the woods and irritate a bear with my pea-shooter......I'm pretty sure that will do it...........
Well I could unplug it not gonna though because it works fine without a bystarter.Bear45-70 wrote:Well nice job, you have RUINED the carb because now another bystarter will not work on it.toad772 wrote:The bottom end I drove a nail into it a bit then cut it off flush with my scroll saw and the top part were the by starter goes I put the needle in and filled the hole with rtv silicone gasket maker(Both holes could be unplugged if I ever wanted to buy a new bystarter)dun rite wrote:Hello: what did you fill the holes with?
