Spree Side Stand Design....Complete
- richdavison34
I finally got around to designing a side stand for the Spree.
I started out with a universal kickstand from monsterscooterparts.com, and went from there.
The design I came up with utilizes holes that are already in the floorboard supports.
I think it came out really good. Let me know what you guys think.
- yhst-92821211804676_2160_110400028.jpg (56.05 KiB) Viewed 28103 times
- IMG_3830.jpg (102.66 KiB) Viewed 28103 times
- IMG_3828.jpg (101.05 KiB) Viewed 28103 times
1984 Honda Aero 50.
Carb Swap. Cone filter.
1984 Honda Aero 50.
- richdavison34
Re: Spree Side Stand Design....Complete
- IMG_3836.jpg (99.5 KiB) Viewed 28102 times
- IMG_3835.jpg (145.44 KiB) Viewed 28102 times
- IMG_3833.jpg (116.18 KiB) Viewed 28102 times
1984 Honda Aero 50.
1984 Honda Aero 50.
- richdavison34
- IMG_3844.jpg (164.49 KiB) Viewed 28102 times
- IMG_3838.jpg (116.17 KiB) Viewed 28102 times
- IMG_3837.jpg (109.53 KiB) Viewed 28102 times
1984 Honda Aero 50.
1984 Honda Aero 50.
- richdavison34
- IMG_3849.jpg (84.45 KiB) Viewed 28102 times
- IMG_3845.jpg (173.32 KiB) Viewed 28102 times
1984 Honda Aero 50.
1984 Honda Aero 50.
- richdavison34
Thanks to my buddies Don and Andy for helping me out along the way.
Thanks again to 66SIX for letting me borrow the frame!!
1984 Honda Aero 50.
1984 Honda Aero 50.
Looks great!
Does it stick back far enough to be easy to kick down when the floorboard is installed?
1986 Spree w/ '87 SE50 motor
- richdavison34
Probably not. I personally think it needs a bigger pad on the bottom too.
In order to make the kick down process easier, I'll be welding on a tab that will stick out a little past the floor board....
Something like in this pic.....
- Motorcycle-Kickstand-Kritter-Pucks 1.jpg (147.34 KiB) Viewed 28078 times
1984 Honda Aero 50.
1984 Honda Aero 50.
How sturdy is the stand and when will you make 89-01 elite side stands?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- richdavison34
The stand is extremely sturdy. It splits the load between both of the foot board supports. The bolts can be a little larger if you want, those were just some i had laying around the shop to show how it works.
I don't have an 89-01 elite frame to work from. I could fab one up pretty quickly if I knew the dimensions.
1984 Honda Aero 50.
1984 Honda Aero 50.
I have a bare frame. Could i send you a pic and you tell me what dimensions you need? I'd donate the frame for the first stand you make but who wants to pay to ship it
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- richdavison34
evilone wrote:I have a bare frame. Could i send you a pic and you tell me what dimensions you need? I'd donate the frame for the first stand you make but who wants to pay to ship it.
Here is a pic of the measurements I need from your frame......
Please send some detailed pics of that area of the frame as well. I should definitely be able to make one for you.
- IMG_3844.jpg (106.05 KiB) Viewed 28046 times
1984 Honda Aero 50.
1984 Honda Aero 50.
Green = 5 inches (I found rail is missing on the left side but you can see the right one in the pic. Left side of pic is front of the elite)
Yellow = 6 19/32 inches
Red is hard to measure
. Do you want the measurement at the middle set of holes?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- richdavison34
Yup, the center set of holes is what I need.
If you don't have that missing bar, then I'll have to custom make a design specifically for your scoot.
There are a couple of more measurements I'll need in that case....
1984 Honda Aero 50.
1984 Honda Aero 50.
- richdavison34
Here you go....I need these measurements.
- framemount.jpg (51.32 KiB) Viewed 27972 times
1984 Honda Aero 50.
1984 Honda Aero 50.
My scrap frame is missing the bar but my complete elite has both bars so i don't need a "custom" job.richdavison34 wrote:Yup, the center set of holes is what I need.
Green = 5 inches (that's with the bar, forget about the missing bar
Yellow = 6 19/32 inches, real close to 6 5/8 inches
outer holes center to center = 7 3/4 inches (red line in the last pic)
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
