(I have posted random junk around here the past few days, so I decided instead of spamming boards and reiterating myself in different topics, I will keep this and the Spree Chopper topics active. I'd delete the others if I knew how)
However, after messing with more wiring, and the multimeter I noticed there was no power going past my relay. It went to the relay, but no power to the switch
So, I am going to guess that is bad. I decided against getting another harness after realizing how stupid I was. Also, it helps I know an electrician that had absolutely no trouble finding the problem.
Also, I noticed I have a turn signal as a tail light, hence why it didn't change brightness.
I will hopefully have these problems sorted out tomorrow.
I am calling this 'restoration' because I am essentially properly redoing my poor little beaten and abused Spree.
