I believe from too much light testingWheelman-111 wrote:Greetings:
Did the battery die from too much light-testing, or is there a current drain somewhere?
1986 Spree restoration
Re: 1986 Spree restoration
Blew a head gasket. How? Not sure. My friend diagnosed it, new head gaskets will be in on Thursday.
What numbers did the compression test throw?
BTW dont know fi you have replaced that flasher relay yet that everyone was giving you such a hard time about but if there is a truck stop near you, you should be able to get one for 5 or 6 bucks as opposed to 15 or 20 for an old one that came on Spree. Any 2 prong 12v flasher relay should work. I got a heavy duty flasher relay from the truck stop for my c70 passport and come to find out my bulb was blown hahah soo i have had it in my junk box till I noticed one was missing on this other Spree I got so I hooked it up and works fine
will save you a few bucks
Thanks. I guess I didn't update that. I bought a flasher from Autozone (the guy that worked there had the same problem and gave me a part that'd work) it was slightly different so I crimped some ends on the exposed wires (that I exposed) and they work now. However I haven't been able to test them yet since my motor has been not running.Mystic wrote:BTW dont know fi you have replaced that flasher relay yet that everyone was giving you such a hard time about but if there is a truck stop near you, you should be able to get one for 5 or 6 bucks as opposed to 15 or 20 for an old one that came on Spree. Any 2 prong 12v flasher relay should work. I got a heavy duty flasher relay from the truck stop for my c70 passport and come to find out my bulb was blown hahah soo i have had it in my junk box till I noticed one was missing on this other Spree I got so I hooked it up and works finewill save you a few bucks
Haven't done one. I'll get to doing one within the next week or so. Helping a friend move so I have been really busy.Bear45-70 wrote:What numbers did the compression test throw?
I am starting to hate everything about this moped. Every thing is annoying about it. Now, the fuel lines shrunk, and won't reach the carb.
how could they shrink that much??? Sure there routed proper??
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
arreche air filter
v8 pipe
stock gears
I have no clue. They were off for one night. now they hardly touch the carb. If I strech them on and put the clamp on the slide back off and the lines really tight.dun rite wrote:how could they shrink that much??? Sure there routed proper??
either some one cut your fuel line without telling you, or you pick up a different line instead.
I don't mod my scooters to go Fast, just want to keep it running!
87 Elite SE50
86 Elite CH150
98 Yamaha Zuma 50cc
87 Elite SE50
86 Elite CH150
98 Yamaha Zuma 50cc
Once again, another dumb question. What do both of the lines do? Is one a vaccuum? Or is it a return? Either way I need to get new lines, I was wondering if it made a difference. All I know is that they're all of a sudden too short to be used on this moped. :/
The top line off the petcock is the fuel feed from the tank to the carb.adios1344 wrote:Once again, another dumb question. What do both of the lines do? Is one a vaccuum? Or is it a return? Either way I need to get new lines, I was wondering if it made a difference. All I know is that they're all of a sudden too short to be used on this moped. :/
The bottom line is the vacuum to operate the valve in the petcock, so that fuel will only flow when the engine in being cranked or running.
did you re-install your petcock correctly?adios1344 wrote:Once again, another dumb question. What do both of the lines do? Is one a vaccuum? Or is it a return? Either way I need to get new lines, I was wondering if it made a difference. All I know is that they're all of a sudden too short to be used on this moped. :/
87 Elite SE50
86 Elite CH150
98 Yamaha Zuma 50cc
87 Elite SE50
86 Elite CH150
98 Yamaha Zuma 50cc
How can you not reinstall the petcock properly? Now connecting the lines backward yeah, but actually installing the petcock on the tank is pretty tough to screw up.wood10214 wrote:did you re-install your petcock correctly?adios1344 wrote:Once again, another dumb question. What do both of the lines do? Is one a vaccuum? Or is it a return? Either way I need to get new lines, I was wondering if it made a difference. All I know is that they're all of a sudden too short to be used on this moped. :/
I've taken the petcock off once to empty the tank, but it screwed back in, and have never removed the lines from the petcock. This is someone else's doings. (I know you weren't even mentioning me in that, but I though I'd clear it up)Bear45-70 wrote:How can you not reinstall the petcock properly? Now connecting the lines backward yeah, but actually installing the petcock on the tank is pretty tough to screw up.wood10214 wrote:did you re-install your petcock correctly?adios1344 wrote:Once again, another dumb question. What do both of the lines do? Is one a vaccuum? Or is it a return? Either way I need to get new lines, I was wondering if it made a difference. All I know is that they're all of a sudden too short to be used on this moped. :/
