headlight not working!!
Re: headlight not working!!
See that?
- IMAG0272.jpg (52.62 KiB) Viewed 2495 times
- Trafficjamz
How did you remove the glass?
Witchcraft.....hahha nah it was already broken out a long time ago whoever scratched their initials in there
So your theory and thinking is to unsolder it regardless if it is bad or not. Also you do not have to unsolder anything to test it. Only a moron would screw up the head light to test it. You are assuming facts not in evidence.Mystic wrote:I decided to show you right now how it can be unsolderednewbie indeed
No you are putting words in my mouth bear. He said he couldnt get the headlight apart for one and thats how you get it apart. I just sorta figured he already knew how to test to see if it was any good before he went through the trouble. I already know for certain mine is bad
If you dont know andy, you can test the bulb by touching a multitester to the ends of the wires where they hook into the bulb, if the hands move the bulb is good ground is green I believe and white and blue are hot
