Half throttle faster than WOT?
On my 125cc stroker setup
1/8th mile run @ 1/2 throttle = best time of the night 10.9sec
1/8th mile run @ Full throttle = avg time of 11.15 sec
Kyrptonite has also reported fastest time with only 1/2 throtte.
Why is this? :confused:
SpreeMadness520
Re: Half throttle faster than WOT?
Post by SpreeMadness520 »
:surprise: Maybe I should try half throttle :crazy:
130cc Stroker
1984 Porsche 944
1965 Vespa
evilone
Post by evilone »
Overcarbed?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
That suggests it's too lean. Too much carb for the setup is also possible.
What RPM at WOT?
evilone wrote:Overcarbed?
BINGO!
You would be better off with a CV carb this big.
BINGO!
CV carb? :confused:
would a 28mm carb help?
Wheelman-111 wrote:Greetings:
What RPM at WOT?
The highest RPM @ Wide open is 10300 with 9.1 gears.
I suspect that my current pipe make little to no power after 9500.
Holding it at half throttle kinda put me in the "sweet spot" for longer. Max revs @ Half throttle was 9800rpm
Trafficjamz wrote:
BINGO!
CV carb? :confused:
A CV carb has a normal throttle valve, but the slide is controlled by the a vacuum diaphragm. This makes the engine only see as much the carb as it can handle. CV carbs are used on Quads and 4 stroke scooters.
CV carb? :confused:
Oh Yes I have lots of those.... most are from 50cc gy6 china copies.
Should I get one for the 150cc gy6 :?:
They make very big CV carbs, Harley Davidson runs a pair of 40 mm CV carbs. My 250 4 stroke quad has a 32mm CV carb while my 400 (actually 376 cc) 4 stroke has 34 mm CV carb. You can't make the motor stumble by crashing the throttle wide open.
Trafficjamz wrote:
CV carb? :confused:
I have no clue how big the carb is for the 150cc gy6? But go at least as big as you have now.
bakaracer
Post by bakaracer »
Trafficjamz wrote:On my 125cc stroker setup
what size carb and what pipe are you using with your 125cc setup?
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
30mm oko carb
gatekeeper
Post by gatekeeper »
Bear45-70 wrote:
Trafficjamz wrote:
CV carb? :confused:
My gy6 150cc engine came with a 24mm cv carb on it.
1985 Honda Spree
2008 Adly Thunderbike 150
2006 NST MPS50
bakaracer
Post by bakaracer »
what size inlet is on that pipe? have you tried changing the main jet by going smaller or larger? what temps are you seeing at wot?
91 yamaha tzr 250r
