Gyro - general thread
Re: Gyro - general thread
Fender & cover again came out as good as yours /mine had more damage
- 100_2055.jpg (55.3 KiB) Viewed 20018 times
- 100_2054.jpg (54.68 KiB) Viewed 20018 times
- 100_2053.jpg (64.26 KiB) Viewed 20018 times
Only had one Black Honda Decal
- 100_2083.jpg (69.91 KiB) Viewed 20018 times
- 100_2065.jpg (64.1 KiB) Viewed 20018 times
- 100_2075.jpg (54.87 KiB) Viewed 20018 times
OK I really think both bikes are done .
Yours needs a petcock .I will try to redo some later wish me luck ... and a battery that fits .And a tube for rear tire I might try to patch it again later this week also a small peice of red vinyl for the plastic above the battery and pick up your new re done seat .Oh and the plastic part for the speedo .
Mine needs 1 black decal ? Changing the battery leads for better ones / like I did to yours . Also I might try to put a red LED on the back of the fender and use it for a running light .
Tazz both bikes came out really well I think your seat is going to really make it .
- 100_2123.jpg (62.01 KiB) Viewed 20018 times
- 100_2119.jpg (83.59 KiB) Viewed 20018 times
- 100_2111.jpg (107.52 KiB) Viewed 20018 times
- bradthreee
I thought this thread would have helpful general information about the gyro, not your personal build thread
C'mon 66SIX......would really like to know what is the product used to paint the seat???????
Hello Brad 3bradthreee wrote:I thought this thread would have helpful general information about the gyro, not your personal build thread
You are right I tried to post some stuff here a while back as no one was posting stuff and couldn't find the gyro thread .Then Tazz asked me to re-do his bike I started putting how his bike was progressing and it kinda got away from me . Also it has been so hot here I started working on the bikes at night then take a few pics and used it as a excuse to get out of the heat and have a drink . But I agree with you it should have been a build thread . Sorry I am wondering if I should just go back and delete most of this stuff as Tazz will hopefully be picking up his bike soon . Lesson learned.
Also I would like to see more pics of your bike ,
Hello Mike better late than never .I took some seats in to have recovered the guy is really good and I asked him is there anything that will bring back the color ?motormike wrote:C'mon 66SIX......would really like to know what is the product used to paint the seat???????
He showed me a can of dupli color and said it works quite well . I asked where do I get it I thought some over priced automotive speciality paint store .
He said PepBoys.
Went down grabbed a can ... looked better than I ever expected .
It actualy seems more like a dye than paint .
Even on the fenders I was very happy with the finished look .
- Screen shot 2011-07-16 at 2.08.jpg (188.37 KiB) Viewed 20000 times
- 100_2130.jpg (214.62 KiB) Viewed 20002 times
- bradthreee
You know I'm just giving you a hard time Dave, I enjoy seeing your pics
Jolly good....I will be using the Dupli-color to do the seat on Get Bent.....thanx dave.........
OK Mike make sure your seat is vinyl as it looks like sh@t on leather , Please do a test spot befor you go crazy on the whole seat .motormike wrote:Jolly good....I will be using the Dupli-color to do the seat on Get Bent.....thanx dave.........![]()
I hope to see some before and after pics .
Good luck I know it will come out great .
Also light coats.
I dont understand how this product can withstand the pressures of sitting on it and stretching.....thanx for the tips....will post up when it happens.........
I am not sure but it's more like a dye than a paint , you will see when you spray it .motormike wrote:I dont understand how this product can withstand the pressures of sitting on it and stretching.....thanx for the tips....will post up when it happens.........![]()
If you look at the pics of the fender its hard to see but it has a matt finish to it , so don't think it's going to be glossy but it still has a bit of a shine to it .
I just think it looks really good and I hope you get the same results .
I was missing a battery holder ...
So I made one ...
EASY ...
So I made one ...
EASY ...
- No I didn't rivit into the battery .
- 100_1145.jpg (57.35 KiB) Viewed 19960 times
- 100_1144.jpg (61.23 KiB) Viewed 19960 times
I have a Gyro with a cracked block .
I took it to a welder he wanted $100.00 to weld it .
I also have a spare engine for parts .
I thought I might be able to switch blocks ?
Bad idea ... what is all that stuff ?
- 100_1172.jpg (58.11 KiB) Viewed 19960 times
- Tryed to put it back together .
I think thats where the horn goes? - 100_1159.jpg (66.24 KiB) Viewed 19960 times
- Why would anyone put a left hand thread in there ? I have watches with less parts .
- 100_1148.jpg (73.96 KiB) Viewed 19960 times
I go fishin' and when I get back, you've fileted a gyro.........
