NEED IDEAS FOR A CHEAP, FAST BIKE
dun rite
Re: NEED IDEAS FOR A CHEAP, FAST BIKE
Post by dun rite »
PimpinSpree wrote:Definitely will make your motor run poorly
x1
either buy or make a new one, don't think patching will work.. good find.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
jlynn433
Post by jlynn433 »
x1
i just patched it and put a layer of gasket sealer over it. it definitely seals now. the only problem is i need to adjust my carb because it is adjusted to when i had the leak. does anyone know the stock settings?
'00 Honda Elite S.....................'06 Yamaha Zuma
-80cc Taiwanese BBK...............-Taiwan pwr pkg
-Malossi Vari
-6.9:1 Primary gears
-High Energy Ignition Coil
-Carbon Fiber Reeds
-Chrome CT Mani
-28mm OKO Carb
-Uni Pod Filter
-PG Long pipe
dun rite
Post by dun rite »
download the service manual here. http://www.hondaspree.net/other/SA50_88-02_service.pdf
1 7/8 turns is the starting point. read the adj. procedure in the manual on how to fine tune for your engine.
arreche air filter
v8 pipe
stock gears
jlynn433
Post by jlynn433 »
ok so i downloaded the manual, and i did exactly what it said 1 7/8 out. i moved the screw from all the way lean to all the way rich and it still kept bogging out. i dont know what to do i tried every adjustment possible :cry:
-Malossi Vari
-Carbon Fiber Reeds
-Chrome CT Mani
-28mm OKO Carb
-Uni Pod Filter
-PG Long pipe
PimpinSpree
Post by PimpinSpree »
did you put a new spark plug in? Although that may not be the culprit, since you were overly lean, not rich
jlynn433
Post by jlynn433 »
ill be getting one today actually. do you think it might be the fix to the problem?
-Malossi Vari
-Carbon Fiber Reeds
-Chrome CT Mani
-28mm OKO Carb
-Uni Pod Filter
-PG Long pipe
dun rite
Post by dun rite »
a thorough carb cleaning might be in order. use the wikispreedia under technical. follow the carb cleaning guide and check out the picture tutorial. if theres a lot of scale & or varnish, get a carb cleaning bucket kit from auto parts store and soak the carb. overnight. spray cleaners don't always do it,
arreche air filter
v8 pipe
stock gears
jlynn433
Post by jlynn433 »
dun rite wrote:a thorough carb cleaning might be in order. use the wikispreedia under technical. follow the carb cleaning guide and check out the picture tutorial. if theres a lot of scale & or varnish, get a carb cleaning bucket kit from auto parts store and soak the carb. overnight. spray cleaners don't always do it,
thats exactly what i was thinking to do. i clean the carb monthly just for the * of it cuz it makes me fell better about my performance, but i think youre right on the overnight soak
-Malossi Vari
-Carbon Fiber Reeds
-Chrome CT Mani
-28mm OKO Carb
-Uni Pod Filter
-PG Long pipe
jlynn433
Post by jlynn433 »
ok i just put the carburetor on. its been soaking since 12 noon. its 1030 pm right now. i tried tuning it, and theres still no difference, it just bogs. should i buy a set of different main jets to test and see what works best with my engine?
-Malossi Vari
-Carbon Fiber Reeds
-Chrome CT Mani
-28mm OKO Carb
-Uni Pod Filter
-PG Long pipe
iRiE S0ULJAH
Post by iRiE S0ULJAH »
if you want a fast bike buy a polini corsa pg long 7.1 gears ct chrome 28 oko kelly pulley sef ramp wit polini guides s trans or zx trans 15 center spring n 3000 clutch spring wit 42 or 39 gram weights.
jlynn433
Post by jlynn433 »
iRiE S0ULJAH wrote:if you want a fast bike buy a polini corsa pg long 7.1 gears ct chrome 28 oko kelly pulley sef ramp wit polini guides s trans or zx trans 15 center spring n 3000 clutch spring wit 42 or 39 gram weights.
my dilemma is that im spending 40 bucks, and my scooter will get me from point a to point b. when i get the money i need to get the corsa kit and oko carb at the same time so that i can still ride it. after that im gonna save for a variator and clutch with a 1500-2000 rpm spring. its my daily driver cuz im 15 and cant drive a car but i need the bike to work
-Malossi Vari
-Carbon Fiber Reeds
-Chrome CT Mani
-28mm OKO Carb
-Uni Pod Filter
-PG Long pipe
dun rite
Post by dun rite »
out of curiosity, have you done a compression test?
arreche air filter
v8 pipe
stock gears
jlynn433
Post by jlynn433 »
dun rite wrote:out of curiosity, have you done a compression test?
im going to be doing that later i know it should be around 114-117 psi (7.0:1) correct?
-Malossi Vari
-Carbon Fiber Reeds
-Chrome CT Mani
-28mm OKO Carb
-Uni Pod Filter
-PG Long pipe
dun rite
Post by dun rite »
:thumbwink:
arreche air filter
v8 pipe
stock gears
jlynn433
Post by jlynn433 »
it turns out that i dont have a compression tester, but i can get one at harbor freight for like 15 bucks, nbd. im probably not going to even attept to start the engine for a couple days, until my jets and rollers that i ordered get here. im going to get my engine re-ported and polished at the local shop: macomb powersports, and i got the new plug, which is a BPR6HSA. the p means protruded tip, and the guy that sold it to me said it was better for the race applications im putting on. i will keep you guys posted on this fix/build as it comes along.. thanks for your guys input and help. :2thumbs:
-Malossi Vari
-Carbon Fiber Reeds
-Chrome CT Mani
-28mm OKO Carb
-Uni Pod Filter
-PG Long pipe
