This is how it's done my children.
benjammer112
Post by benjammer112 »
this is how it's done, 6.5 hp motor bolted to the floor board with some welded on pulleys, the coolest/lamest deathtrap ever.
i ride so fast that my scooter flies into the sky and i rain chocolate on the little children.
wood10214
Re: This is how it's done my children.
Post by wood10214 »
Look scary to me :nervous:
I don't mod my scooters to go Fast, just want to keep it running!
87 Elite SE50
86 Elite CH150
98 Yamaha Zuma 50cc
fastplastic
Post by fastplastic »
wow epic fail good luck :crazy:
Dude! Swap in a Briggs and Stratton!!
Does it function? If so it is the coolest resurrection ever! Maybe install some footpegs somewhere...
dun rite
Post by dun rite »
Inventive. i'd suggest a belt guard though :smile:
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
Footpegs??..........belt guard??..........Naw, man.....what it needs is a bottle.......... :bowrofl:
Palero2003
Post by Palero2003 »
Thinking outside of the box I guess lol. But if works right on!
ERROR 1604
Belt guard+++
Looks like the OEM engine still has it's intake and carb. Are you running the injection pump to oil the case bearings?
If the piston/cyl is intact, a check valve in place of the spark plug and plumbing would make a low output/low pressure compressor. Maybe enough to drive an air brush and paint itself - or run a set of air horns.
Quoth The Mouse:
Now ah don' care who y'are or how much money ya got, tha's some funny stuff rat thar! :)
At 9:1 compression ratio, you'd have something like 135PSI. It could keep its own tires inflated too!
You do make a good point about keeping the bearings lubed, but I guess one could lose the connecting rod and piston altogether and just squirt some oil down the plug hole once in a while.
I nominate this for an award....."Best Innovative Thought".......makes me sit back wonder what kind of mind was at work to think this one up......Rah!.....Rah!.....Rah!.. :woot:
maddog
Post by maddog »
you are now qualified to work at a John Deere plant :smile:
fastplastic
maddog wrote:you are now qualified to work at a John Deere plant :smile:
:thumbwink:
:thumbwink:
First time I have ever seen Maddog say anything I could agree with.
I hope this was meant to be a joke.
There is no way this piece of $hit runs or moves.
The front pulley is a clutch mounted backwards :confused: with no nut to hold it in place.
The clutch pucks are just flinging around all over the place, with no bell to keep them from flying off.
Suddenly TrafficJamz = Buzzkill! :)
The front engine would make a hellova Dio starter.
