1987 elite SE50P de-restrict
Re: 1987 elite SE50P de-restrict
where is the hole that is plugged on the sa50p airbox? i want to fully derestrict the bike and this is the only thing left
'00 Honda Elite S.....................'06 Yamaha Zuma
-80cc Taiwanese BBK...............-Taiwan pwr pkg
-Malossi Vari
-6.9:1 Primary gears
-High Energy Ignition Coil
-Carbon Fiber Reeds
-Chrome CT Mani
-28mm OKO Carb
-Uni Pod Filter
-PG Long pipe
-Malossi Vari
-Carbon Fiber Reeds
-Chrome CT Mani
-28mm OKO Carb
-Uni Pod Filter
-PG Long pipe
picked up a 87 se50p today, i see the restricted exhaust and can only assume it has the restricted plate granted the high 20s speed.
im pretty familiar with cvts however, does anybody recommend one variator/plate over another? Can i just take off the restricted plate ?
anybody have one they are looking to get rid of?
What will you use for a plate if you remove it? The ramp plate needs replaced not removed. Get a Keli variator and a non-restricted ramp plate.DERP wrote:Can i just take off the restricted plate ?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
thanks for the reply do you think i would see around 50mph with a 65mm big bore kit, new ramp, and the variator?
http://cgi.ebay.com/ebaymotors/AIRSAL-6 ... arQ5fParts
Yes you should see 50 mph. Forum member martynkim does it without a big bore.
You're going to get an unrestricted pipe right?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
planned on making a pipe at school
but wait a hoot
http://www.partsforscooters.com/169-210 ... gory=74117#
does this kit work on the se50p?
but wait a hoot
- Trafficjamz
nopeDERP wrote:planned on making a pipe at school
but wait a hoot
That is a kit for a yamaha horizontal engine.
dam saw 10mm wrist pin and got all excited lol
thanks for the tip
thanks for the tip
that1mopedguy
- Goped
i already have an un-restricted muffler on my 89' sb50p. is it possible for me to get a keli variator too?
absolutely not
your best bet for more speed on the sb50 is to swap in a variated engine
that1mopedguy
- Goped
where can i get a variated engine?
first and best place to look is your local salvage or junkyard
your best bet is an af16e "dio" motor from a 94-2001 honda elite or the variated af05 from an 87 elite se50, 88-93 Sa50 elite or Aero nb50
that1mopedguy
- Goped
kk. cool. thanks
i'll keep an eye out and look around. let me know if u can find one too. lol
evilone wrote:How to remove restrictions from 1987 SE50P. These are the major restrictions. Muffler does not have a washer to drill out and restricted ramp plate ramps are flat, muffler and ramp plate need replaced with non-restricted.
Restricted SE50P ramp plate
Un-restricted SE50 ramp plate
Restricted SE50P muffler
Un-restricted SE50 muffler
were would i go to find those parts?
Here or ebay
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
