I'm going crazy. Losing spark when hitting bumps/pitch diffs
Re: I'm going crazy. Losing spark when hitting bumps/pitch d
so you have a bad/lose connection the engine somewhere. start wiggling wires until you find it.
z50r-ghost
Post by z50r-ghost »
X2...
Sounds like a wire is getting grounded out somewhere possibly around the engine mount / pivot points.
I fixed a friends NS50 that had a loose wire connector tab at the CDI. I used a dental pick to remove the metal plugs on the harness at the CDI, carefully squeezed the connectors to tighten their fit, and plugged them back into the plastic plug housing.
As well, I have seen coils that stop sending spark when a bump is hit, and I've also seen a few bad NEW NGK spark plugs... Not common, but possible. Be sure you don't overtighten the plug. When a plug is overtightened, the gasket is destroyed, and more strain is placed on the plug body above the threads.
-j
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
Chicago Ben
Post by Chicago Ben »
This is my argument against loose wires:
In my video you can see this too. (on pg 1) , when I take the bike going forward over the wood bump, it dies out when the rear wheel drops back down. But if I hit that same bump in reverse, it doesn't do anything.
I think this has to do with my float/carb/fuel somehow.
I have jiggled every wire at idle and nothing cuts out the engine like this.
For my ultimate test, I even had the bike idling, kickstand was up (not in use) , I lifted the rear of the bike up and tried to replicate a bounce (picked up and dropped down about 2 inches) this didn't do it.
Maybe my float level is too high?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
1000k Polini triples
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
I am going nuts.
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
I can replicate this event by going both forward and reverse over a bump and by lifting the back up anddropping it (~3inches)
I lowered my float level...still same issues
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Mystic
Post by Mystic »
did you check for a leak around where the exhaust bolts on?
Chicago Ben
Mystic wrote:did you check for a leak around where the exhaust bolts on?
Yeah no nice. Nice n snug.
My only idea is wires to stator are shorting. This is so d*** annoying.
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Pancake808
Post by Pancake808 »
Check the wire / ground to the coil!!!!!!!!!!!! Had a similar prob check it out....
Chicago Ben
Pancake808 wrote:Check the wire / ground to the coil!!!!!!!!!!!! Had a similar prob check it out....
at the coil ? or at the battery?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
The battery has NOTHING to do with the ignition. The battery is mainly for starting.
Chicago Ben
I understand that- I'm talking about the wire harness closer to the battery as apposed to closer to the actual coil
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
This is interesting... if I tip the bike backwards (parking the bike on a normal slanted street where the rear tire is kissing the curb) the bike revs up as if it is getting more fuel...? my fuel line is pretty long and it kind of dips below the intake point on the carb before mating up with that nipple... could it be that I'm starving the bike of fuel for a split second on bumps?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
evilone
Post by evilone »
Sounds like a possibility. Shorten that fuel hose.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Chicago Ben
evilone wrote:Sounds like a possibility. Shorten that fuel hose.
I'm gonna try that out next weekend, I'm in the middle of another move , we all know how much fun moving is
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
:imo: Too long of a hose would not cause the problem you are having.
Ben, I really think this is an electrical issue. I can send a couple of parts your way so you can troubleshoot, if you want.
