parts questions
bdcorrigan
parts questions
Post by bdcorrigan »
Do the motor off the sa50 or se50 fit the nq50 motors. I want to put new gears and a 44mm bore kit on the nq50 but can't seem to find the aftermarket gears for it.
sprite2011
Re: parts questions
Post by sprite2011 »
That's a negative ghostrider. You need to do an actual motor swap if you want to go.faster.
Re: parts questions
sprite2011 wrote:That's a negative ghostrider. You need to do an actual motor swap if you want to go.faster.
Sprite, This is incorrect, the Spree will actually go faster with just the gear change, but the poor launch ability will get even worse without the BBK to make more low end torque. To swap any other engine into your Spree will require fabricating a motor mount to make it work.
sprite2011
Re: parts questions
Sorry misread his question.
Re: parts questions
bdcorrigan wrote:Do the motor off the sa50 or se50 fit the nq50 motors. I want to put new gears and a 44mm bore kit on the nq50 but can't seem to find the aftermarket gears for it.
Oh and the gears are available from the same dude that has the Spree BBK. That's tazland001 here on the forum. Contact him.
Palero2003
Re: parts questions
Post by Palero2003 »
If have acess to a welder and know how to weld!!!(don't risk it on popcorn s***) or know someone who can scoots are pretty easy to fab mounts and stuff. If have worked on cars and trucks with custom mods(not bolt ons) then it's cake. Maybe 5-10 10/10 being body dropping trad or sf
ERROR 1604
