so I decided to get rid of the air box
89eliteR
Re: so I decided to get rid of the air box
Post by 89eliteR »
Trafficjamz wrote:
89eliteR wrote:So I took it for about a 15 min drive and I now notice the exaust heats up quite a bit. Would it not be getting enough air now? It doesn't bog down, nor does it seem to lose any power.
the exhaust is supposed to get hot :smile:
Do a plug chop to tell if you are running lean or rich. :wink:
So how would I got about doing a plug chop? I checked the wiki spreida but could not find anything. And I fear this soft seize, and would very much would like to avoid it without sacrificing the mod.
martynkim
Post by martynkim »
New plug run at WOT for about a minute should tell the story. Shut the bike off at WOT.
dun rite
Post by dun rite »
89eliteR wrote:So how would I got about doing a plug chop? I checked the wiki spreida but could not find anything. And I fear this soft seize, and would very much would like to avoid it without sacrificing the mod.
you missed this. http://hondaspree.net/wiki/index.php5?t ... Plug_Chops
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
89eliteR
Post by 89eliteR »
martynkim wrote:New plug run at WOT for about a minute should tell the story. Shut the bike off at WOT.
What would I be observing at that point? I know the spark plug, but would it be burned/discolored?
89eliteR
Post by 89eliteR »
Thanks that's perfect.
89eliteR
Post by 89eliteR »
So I am attempting that test now with the new plug, but I'm stumped as to what kind of wrench/ socket it is to remove the plug? Any help?
dun rite
Post by dun rite »
spark plug socket, 13/16 deep well I think. one made for spark plugs have a rubber insert that helps to keep from breaking the ceramic part.
arreche air filter
v8 pipe
stock gears
89eliteR
Post by 89eliteR »
The plug chop was done with a new spark plug, and the result is a little bit of oil, very light tan mostly, a little bit of black where the metal part folds over the tit, and a little bit of brown below the space between the tit and the metal part that it goes over.
89eliteR
Post by 89eliteR »
Here is the finished well working product, thanks again for all the help guys!
martynkim
Post by martynkim »
Pictures of the plug?
89eliteR
Post by 89eliteR »
martynkim wrote:Pictures of the plug?
Way too lean still, if you did the plug chop properly.
89eliteR
Post by 89eliteR »
Bear45-70 wrote:Way too lean still, if you did the plug chop properly.
I used a new plug, held it wide open throttle for 1 min, then cut the engine at wide open throttle. Ill do a second test tomorrow and maybe hold it a little longer? I have been adding extra oil to the gas after i did that test to be on the safe side.
dun rite
Post by dun rite »
you were riding the bike right? not just revving on the stand.
arreche air filter
v8 pipe
stock gears
89eliteR
Post by 89eliteR »
dun rite wrote:you were riding the bike right? not just revving on the stand.
no reved it on the stand.
