Need Help malossi leaking base gasket
so the other day i decided to test for intake leaks using carb cleaner around the manifold to case and cylinder to case (i dont know if that was the correct way to do it but i was very gentle with the spraying)
anyway found that when i sprayed between the manifold and the cylinder the bike would die out.
- z50r-ghost
Re: Need Help malossi leaking base gasket
Your bore isn't touching your intake manifold, is it? I had a stage 6 (Koso) intake mani that set right against my corsa bore... What gasket are you using; paper or aluminum? I always coat my gasket surfaces in a very light coat of hondabond before installing...
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
...my life story
1990HONDANS50F
I had to remove some material from my intake as well, to let the cyl. fit flat. but that was on a 50mm tazland001 bore.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
arreche air filter
v8 pipe
stock gears
Hmm. You sure theres no cracks at the base of the bore? or in your intake manifold or the block from tightening it to much? It shouldnt be the actual gasket thats the problem..What kind of block are you using?
What area do you live? Maybe could check it out.
- bradthreee
x2 for the Hondabond or I sometimes used the copper RTV sealant...
thanks for all the input.
probably need to put heli coils in place of stripped threads. Even if the torque wrench clicks at 8. Since it won't click at 10 the threads are pretty much gone, and will probably give you problems down the road.. don't know if drilling and tapping to a 1/4x28 would work or not.
arreche air filter
v8 pipe
stock gears
arreche air filter
v8 pipe
stock gears
.what is that? how does it work? and where can i get it? .dun rite wrote:probably need to put heli coils in place of stripped threads. Even if the torque wrench clicks at 8. Since it won't click at 10 the threads are pretty much gone, and will probably give you problems down the road.. don't know if drilling and tapping to a 1/4x28 would work or not.
i really dont want to have to replace my block
thanks
Ol' Red
Broken...
Spreeio
1987 Spree
With af16e powah!!!!
Broken...
Spreeio
1987 Spree
