66SIX Spree Build / YES IT"S FASTER
Re: 66SIX Spree Build / YES IT"S FASTER
I like how you always pay attention to detail. Hook a brotha up with a seat cover
Another nice one 66Six
Another WOW!
Get rid of the purple...
Spree sticker should be replaced with .... Six...
and that d*** purple strip on the seat ...but other aspects of the seat...wow again...
congrats picasso six ...
'86 Aero 50 (NB50)
'01 Yamaha Jog Nextzone
I'm lovin' this one...
SWAG
1984 Honda Spree
1985 Honda Gyro S
1977 Honda Camino
1960 Alpa Moor
2009 Piaggio MP3 400
2002 BMW 330xi
1984 Honda Spree
1985 Honda Gyro S
1977 Honda Camino
1960 Alpa Moor
2002 BMW 330xi
Another test ride ...
more pics .
more pics .
- 100_2627.jpg (48.05 KiB) Viewed 6773 times
- 100_2624.jpg (88.56 KiB) Viewed 6773 times
- 100_2619.jpg (66.5 KiB) Viewed 6773 times
Back to work .
Made a side cover .
Made a side cover .
- Used an old frame and tank to get the cuts right .
- 100_2634.jpg (68.45 KiB) Viewed 6773 times
- 100_2635.jpg (82.72 KiB) Viewed 6773 times
- Started the bends
- 100_2637.jpg (71.78 KiB) Viewed 6773 times
Yes I know it looks goofy .
- More bends more cuts
- 100_2640.jpg (74.05 KiB) Viewed 6773 times
- Painted ... it was 112 today .. dried in 10 min.
- 100_2647.jpg (70.67 KiB) Viewed 6773 times
- 100_2653.jpg (72.56 KiB) Viewed 6773 times
Thats it Im done ... forget the other side for now
- 100_2648.jpg (90.2 KiB) Viewed 6773 times
- Looks weird huh?
- 100_2660.jpg (94.97 KiB) Viewed 6773 times
- 100_2662.jpg (66.33 KiB) Viewed 6773 times
I bought a spree w/ that seat ... and always wanted to use it but the purple ? ? ? After repainting the flame red it was a lot betterMystic wrote:I like how you always pay attention to detail. Hook a brotha up with a seat cover
as for re-doing the purple pipeing maybe later its a pain in the @ss.
Thanks for the comments :
DeathByFox
Awesome scoot. I like that purple stripe in the seat.
Bright lights put me in a dance But it aint house music makes me wanna dance
- tazland001
Need some lights behind the mesh. It would look nice with a soft glow.
Taz
Taz
Yeah - couple of Nixies set to 666, LEDs good too!Need some lights behind the mesh. It would look nice with a soft glow.
Nice photo from the 'net...
You are aware that the no rev limit CDI was a waste of money, aren't you? The Spree already has a no rev limit CDI from the factory and it is a better quality CDI to boot.
OK Tazz / Mousewheels ..I actually did some tests w/ lights behind the side screen cover Its was underwelming to say the least
the real kicker is when i noticed sparks and smoke and some flames ...I was just testing and only stuck the wires on the battery terminals
I tried LEDs then I tried an old turn signal (for more foot candles)...somehow one of the leads was shorting out to the frame and I was wondering why it was getting so hot ???
Yeooow look out ziiittt zittt I tried to pull the wire off but it was red hot and sparking another thing I painted the frame black so there is not much to reflect (catch) the light .
The 666 lamps is a great idea but the mesh is rather small so I don't think it would read well , still thanks for the suggestion (maybe if they were back a bit ?)
OK Bear busted your right on the CDI I only used it for looks the case is a blue aluminum and I just thought it looked cool and I had cut the air filter case off and had an open spot where it
seemed to fit well .
Here are some bad fuzzy photos of what the lights looked like .before the wire shorted out .
Again there is so much black nothing reflects the light / notice the amber on the muffler and on the fender at the top is the lens of the signal light I was testing with .
- 100_2690.jpg (57.75 KiB) Viewed 6705 times
- 100_2689.jpg (73.42 KiB) Viewed 6705 times
- 100_2688.jpg (48.77 KiB) Viewed 6705 times
Also on the subject of lighting I wanted to put LEDs behind the muffler cover .
I have some heat shield material from a company in Austraila and it would probably not be easy to get information on the temps. so close ?
I also had concerns running wires or ground the (- )to the frame and just run a (+) I might have some high temp wire but something so close to the muffler
I don't know ...
I don't know ...
- 100_6212.jpg (49.3 KiB) Viewed 6700 times
- 100_6216.jpg (54.34 KiB) Viewed 6700 times
