Sprelite The Begining Of My Epic Build
- SpreeMadness520
Re: Sprelite The Begining Of My Epic Build
After seeing it all together....Its kinda scary
- awwwwyeah.jpg (167.32 KiB) Viewed 5205 times
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- SpreeMadness520
Trafficjamz Does Nice Work
- awwwwyeah2.jpg (106.43 KiB) Viewed 5205 times
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- SpreeMadness520
Ok I got the engine all figured out put it all together...gased it up....First kick, VROOOM....Instant smile on my face...I need the oko settings...The rear tire spins so i know thats not right....Thanks baka racer jets are good so far...
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- SpreeMadness520
After doing a few heat cycles, I took it for a quick ride (1 block) It kinda bogged and even at full throttle I was only doing like 20 maybe. Im thinking rejetting, Or new rollers? What do you guys think?
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- SpreeMadness520
Changed out the rollers, When people say the scorpion likes light rollers....They mean it, I have 6 grams in it now and it ran like a BEAST Bottom end needs a little work but I might mix 5 and 6 grams.....I learned not to kill it going 30 because gas built up in the hot scorpion and shot fire out of the back
whoops....Still doing some heat cycles stay tuned
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- SpreeMadness520
Alright I have a 50 pilot and a 142 main with 5 gram rollers...It runs good but a bit shuttery on take off any ideas on new jets?
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- fastplastic
change to a 55 its a lil lean....
- fastplastic
my bike is running a 55 142 with my setup and im a lil rich you should make sure you watch your temps closely....
- SpreeMadness520
I couldnt find a 55 in t-jamz plethera of jets, But im going to use a 54 for now...Figured its better than running lean.
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- SpreeMadness520
Sorry I meant I have a 58 pilot....Ill stay there...
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
At what throttle position does the shuttering kick in? Mark your throttle grip at 1/4 ,1/2 and 3/4 and do a test. That will tell you where in your jetting you need to adjust if its a jetting issue that's causing the shutteringSpreeMadness520 wrote:Alright I have a 50 pilot and a 142 main with 5 gram rollers...It runs good but a bit shuttery on take off any ideas on new jets?
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
91 yamaha tzr 250r
- SpreeMadness520
I switched up the rollers and its running perfect, I took it to a compression test and it read 70 psi.....There is no way thats right it runs amazing....
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- Trafficjamz
Ya I got your message......70psi is not right.SpreeMadness520 wrote:I switched up the rollers and its running perfect, I took it to a compression test and it read 70 psi.....There is no way thats right it runs amazing....
I will take a proper reading when I see you at the track.
- SpreeMadness520
I know man I can give it half throttle at 25 and wheelie....There is definitally some more compression?
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- fastplastic
how many times did you kick it........ and was the throttle hung open?
