CH80 only 30 mph?
Re: CH80 only 30 mph?
1957 10 horse Johnson. I have an 1958 18 horse and a 1957 5 1/2 horse Johnson in my basement for my 14 foot skiff.
Oh and the other idiots know less than nothing. I am not a fan of 4 stroke scooter motors. They are heavy and are a b**** on the maintenance side. The only reason they exist is because the EPA left the manufactures no other choice and that is the second reason I don't like the 4 strokes, government interference.
Mystic
Post by Mystic »
Bear45-70 wrote:1957 10 horse Johnson. I have an 1958 18 horse and a 1957 5 1/2 horse Johnson in my basement for my 14 foot skiff.
I am waiting on a carb rebuild kit for the matching 18 sea horse myself :D I have a matching set
wood10214
Post by wood10214 »
I got a 1955 seaking just sitting in the garage also, but can't get it start aafter I took the carb apart. :sad:
I don't mod my scooters to go Fast, just want to keep it running!
87 Elite SE50
86 Elite CH150
98 Yamaha Zuma 50cc
Mystic
Post by Mystic »
nice, i dont know what it is but I like the cases on these old motors reminds me of a 57 chevy :D
I have a 1947 5.5 horse Johnson and a 1947 3.3 horse Evinrude. I had a 1935 3.3 horse but a collector offered me 10 times what I had into it so I let it go. I do have a couple a of 1958-59 50 horse V-4 Johnson (the first 2 years of the V-4) on stands in my shop and a 1967 100 horse on my 1963 15 foot Anthony Brothers fiberglass 3 point hydroplane in my shop also. I also have a 1976 Mercury 1500XS in my shop in the process of being rebuilt.
High performance V4 50 horse
1967 100 horse
Anthony Brothers Jetstar 15 foot Hydro
1976 Mercury 1500XS with race gearcase
Mystic
Post by Mystic »
that mercury is sweet :D I have a huge brass prop I saved from the scrap that may fit that super sea horse :D
Mystic wrote:that mercury is sweet :D I have a huge brass prop I saved from the scrap that may fit that super sea horse :D
That gearcase on the 50 horse is just a lengthened version of the 1960 stock gearcase. So it uses stock props, even though they are modified.
wood10214
Post by wood10214 »
Got the new Roller in and make sure the belt is Good, now it pick up the speed faster, but it still has the top speed at 33-34mph :sad:
Well this time I might need to take off the head again to adjust the valve.
87 Elite SE50
86 Elite CH150
98 Yamaha Zuma 50cc
Mystic
Post by Mystic »
hehehe now you know that if you have the head off of a 4 stroke you should go ahead and clean the valves and adjust the rockers. check the valve seals while you are at it :D not sure but if you have to reseat them its pretty easy as long as you have some valve grinding compound and an electric drill. you can take a wire brush attachment for the drill or even a table grinder with a steel brush on it and polish those valves to a shine, they are made of steel so you cant damage them by doing this :D
wood10214
Post by wood10214 »
Thanks, the part it make me sad is when I remember how nice of everything I put back together :sad:
Will do this on weekend.
87 Elite SE50
86 Elite CH150
98 Yamaha Zuma 50cc
zuphilius
Post by zuphilius »
Just use the manual and ADJUST the valves. You don't need to take the head off to do this. Here's the manual:
http://www.hondaspree.net/phpBB3/viewto ... =11&t=8555
After adjusting the valves, adjust the carb. No need for disassembly.
Keep it simple.
Motley Crue
Post by Motley Crue »
hey mystic and bear, get a room!
MotleyCrue wrote:hey mystic and bear, get a room!
New Yorkers should keep quiet, there are way to many skeletons in any New Yorker's closet, 20 mph boy.
wood10214
Post by wood10214 »
zuphilius wrote:Just use the manual and ADJUST the valves. You don't need to take the head off to do this. Here's the manual:
Keep it simple.
I really like to keep it simple, but I did look the manual and if I need to adjust the valves it has to remove the head, am I missing something in the manual?
87 Elite SE50
86 Elite CH150
98 Yamaha Zuma 50cc
