Tripping stop light sensors
Alright, out with it. What are your tricks and tips for making the stop lights change for you? I was at the bike shop today and saw a little magnetic device that you put on you motorcycle to make the sensors see you. Would this work with just a regular magnet under the scooter? Is it some mystical device or just a 20 dollar magnet?
- hrnytrtlsgsxr
It's just a $20 piece of steel or a magnet... what a racket.
Bicycles had the same problem, I'm surprized that scooters do. Best thing to do would probably be to put a chunk of steel in/on your riding shoes. The closer the steel is to the ground the better it works if it's smaller.
Admin, Hondaspree.net
- 85spreeelite
www.themirt.com Id check this out if you are REALLY serious.
Ouch, $300 for an infared strobe light?85spreeelite wrote:www.themirt.com Id check this out if you are REALLY serious.
- 85spreeelite
You can buy/build an adjustable strobe flasher for about $20, 7 hz (7 times a second) is what they used to be set to. If a cop sees you with a visual flasher (white light) though, you can get an impersonating an officer ticket. You'd need to find a source for these IR-frequency bulbs, and convert one of the visual flashers.
If you find the parts, let me know, I'd be interested.
- 85spreeelite
- burnt_toast
- 85spreeelite
