info on 87 gearing
hrnytrtlsgsxr
info on 87 gearing
Post by hrnytrtlsgsxr »
when the japan dio motors just broke out in hawaii there were no gearing at the time.the olskool guys got the whole set of 87 gaers and installed them in the japan dio motor cause it had a taller gearing ratio.i just got that from billand keoni. Two olskool guys that know their shet. just wanted to let the guys here know that there might be a way to install taller gears in an 87. but i have not had the chance to see if it works the other way around although why shouldn't it.
So the rear gear sets from the '85-86 Aero, '87 Elite, and '94+ Dio blocks are all the same, in terms of pinion center spacing? That's interesting.
hrnytrtlsgsxr
noiseguy wrote:So the rear gear sets from the '85-86 Aero, '87 Elite, and '94+ Dio blocks are all the same, in terms of pinion center spacing? That's interesting.
the information I got was that they took all the pieces out of the 87 gear case and reploced the dio gears with that. i know the the 87 bell fits on the front so that is a tell sign. i know you can use the 87 gear plate on the af16 motor(Us dio).i also know that the main drive shafts are similar in shape and length. the dio gear has to be pressed on the shaft, The 87 has a clip which holds the gear in which sits on the main shaft which is rivited with teeth.No one that I know of tried it the other way yet.
darat
Post by darat »
since it was ur idea u should do it.
MySpree
Post by MySpree »
yea do it to it! so there are gear sets for an aero?
hrnytrtlsgsxr
darat wrote:since it was ur idea u should do it.
I'm not the the one that needs the gearing when I have stroker dio motors what the * would I want to put gearing in an se50. i am just relaying info if anyone wanted to try it out.
bitteraspects
Post by bitteraspects »
indeed. you dont have to worry about the gearing when your bike is over 100cc :wink:
darat
Post by darat »
i have to say that u guys need to find us some gearing for it lol u guys have all the hook ups..
bitteraspects
or you could just transplant a bigger motor, then no problem finding gearing ;)
hrnytrtlsgsxr
for us I think might be harder to get an 87 motor than a dio type motor
