66SIX Spree Build / YES IT"S FASTER
Re: 66SIX Spree Build / YES IT"S FASTER
I like light under the muffler heat shield looks very cool ( how about header wrap on the pipe for heat insulation )
I'm still not keen on the color of the side mesh ....maybe dark red to match the vent cover mesh
Pre-mix if you don't have 2 stroke oil your f u c k ed.
How did I fix that problem ?
I had a space where the old oil tank was ....Duh....
- 100_2740.jpg (33.31 KiB) Viewed 7032 times
- 100_2737.jpg (65.08 KiB) Viewed 7032 times
- 100_2742.jpg (82.23 KiB) Viewed 7032 times
Stopped in at the dollar store ,They had mesh pencil holders ,And looked about the same size as my foam air filter
Guess what they cost ? ....$1.00
A little red paint cut out a skull stencil even less white paint ... Done .
OK I did have to tap the top of the carb to put a 7mm screw in to keep it from falling off .(took less than 1 min.)
- 100_2723.jpg (86.45 KiB) Viewed 7032 times
- RED RUM
- 100_2743.jpg (49.18 KiB) Viewed 7032 times
- Screw in top of Carb.
- 100_2752.jpg (67.96 KiB) Viewed 7032 times
20 Bucks and it's removable.
- scoot trunk .jpg (160.83 KiB) Viewed 7012 times
- I know I can fit a 24 pack in there .W/ Ice
- 100_2758.jpg (56.93 KiB) Viewed 7012 times
- 100_2753.jpg (84.01 KiB) Viewed 7012 times
- burnt_toast
Going great until you added that box, that thing is hideous.. LOL
but i bet its functional
projects galore
- mopro logan
Nice scoot I like the meshing.
.....Ditto on the box......even took my milk-crate off the elite.....got tired of the look.....LIKE the mesh 100%....it's like a naked bike, wearing see-thru teddy....ooh-lah-lah
......case o' beer, bag o' ice, case o' beer, bag o' ice, case o' beer, bag o' ice,.........I hope I can remember why I'm riding this Spree to the store........case o' beer, bag o' ice, case o' beer, bag o' ice................
- mopro logan
That is the only plus to the box lolmotormike wrote:.............case o' beer, bag o' ice, case o' beer, bag o' ice, case o' beer, bag o' ice,.........I hope I can remember why I'm riding this Spree to the store........case o' beer, bag o' ice, case o' beer, bag o' ice................
Well your right on the case of beer and bag of ice .The trunk is removable.
I added more sh@t to the bike Red LED and amp meter & red reflector tape to rims .
- 100_1577.jpg (48.96 KiB) Viewed 6936 times
- 100_1583.jpg (70.69 KiB) Viewed 6936 times
- 100_1585.jpg (80.12 KiB) Viewed 6936 times
Very cool
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Pretty bright LED's, show up well in daylight. How about a night shot
Found an old pipe and figured ...Give it a shot.
I have another thing to put on my do not do again list ...Never try to weld a header or make mounts for a Exhaust pipe .
The metal on the side is the unfinished mount .
On the first test run I got about 1/2 a block before the pipe ripped off the header (should have made a mount & thicker welds )
So back to the welder and thicker welds and deffinatly make a mount .
I noticed a bit more power but it's very loud .Hope to have it finished tomorrow .
- 100_2807.jpg (59.21 KiB) Viewed 6909 times
- 100_2818.jpg (69.93 KiB) Viewed 6909 times
- 100_2826.jpg (38.06 KiB) Viewed 6909 times
- swimmingfree
looks grate and not my grampa spree but didn't like it innhow..
one question why is the back finder still on ??
your not using the air filter so the only thing in the finder is the coil i think??
p.s.
with the new pipe you wont have a spot to bolt the back of the finder on to innhow
p.s.
- mopro logan
I like that pipe on there where did you get it.
