cluches for nq50 help!
are there any better clutch springs out there fore a nq50. if so plz tell
Re: cluches for nq50 help!
You can mod the aftermarket springs for a variated AF05E to work on the spree clutch
DJ1
NEK MINNIT
Malossi
DJ1 54mph
dio gear swap in progress
living in chch NZ
earthquake central
NEK MINNIT
Malossi
DJ1 54mph
living in chch NZ
earthquake central
- Trafficjamz
niftyman wrote:You can mod the aftermarket springs for a variated AF05E to work on the spree clutch
Say what?!?
Yeah, nifty seems to be like the maddog from down under.Trafficjamz wrote:niftyman wrote:You can mod the aftermarket springs for a variated AF05E to work on the spree clutch
Say what?!?
i heard that from some one also but i never tried it
spree parts for sale
still learning alot ..thanks to all on this fourm
if you have a good spree jug ..pm me if you want to sell it
It aint that hard heat one of the ends of the spring and bend the end around more makeing the spring shorter and trim off what u bent round so u can hook it on to the clutch i just keep on bending it so the new spring is the same length as the stock spring fitted them up and it works mint
I did this as i read it somewhere here ill try to find the link
DJ1
NEK MINNIT
Malossi
DJ1 54mph
living in chch NZ
earthquake central
NEK MINNIT
Malossi
DJ1 54mph
living in chch NZ
earthquake central
Dont knock it till you have tried it.It definitly works
DJ1
NEK MINNIT
Malossi
DJ1 54mph
living in chch NZ
earthquake central
NEK MINNIT
Malossi
DJ1 54mph
living in chch NZ
earthquake central
i have 1.5 or 2 k springs that are just sitting around so ill give tit a try
