Motor mount help
Spreet Smart
Motor mount help
Post by Spreet Smart »
I've recently acquired my second Spree. The spree was swapped with an aero 125 motor by the P.O. This thing was slapped together very poorly but I aim to fix that. The motor mount only had the bolts going through it without any type of bushings or spacers making for a ride that was Shamu-ish. What are my options on fixing this so that the motor mounts are solid?
Here are a couple photos for reference:
Spreet Smart
Re: Motor mount help
I should have posted a pic with the bolts next to the openings, but just so you know the bolts are about half the diameter as the openings on the motor mounts shown above.
Petrock's 1984 Spree
Post by Petrock's 1984 Spree »
If you have access to a welder you could take some washers that share the same diameter with the bolts and weld those onto the ends of your mount.
You might have to shave of a little on either side of the tubes before you weld them on to get back t the same over-all length but thats the simpliest fix i can think of
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
Mystic
Post by Mystic »
you can buy rubber bushings and stuff them in there :D
veedubh20
Post by veedubh20 »
Birdshet weld not good.
Spreet Smart
Haha! I was waiting for someone to say that. The P.O. welded that sweet piece together. Guess I cant complain because I've never welded in my life. At least I can tell * welds from good ones. I'm not too worried about it though.
