sprite2011 wrote:Chinese 4 stroke, dump it in the trash. Chinese 2 stroke maybe I will use it, only if its a GY6.
Perhaps you should do your homework before trashing on peoples new toys.
The 139qmb is a lesser cousin of Honda, but it can make for a fun and pretty reliable bike that is cheap to work on, if not as simple as a 2stroke engine.
My cheap china bike is held together with zip ties, mud and good luck. That said, I've put thousands of trouble free miles on it. I haven't started it in weeks, but I'm willing to bet it would still start right up with no protest and run exactly like it always does. The problem with a lot of china bikes is the owners lack of
any mechanical skill. There are definite quality control issues, but the major problems usually manifest within the first few thousand miles. And really, what do you expect from a vehicle that costs $600 new? So you have to iron out the mechanical wrinkles. And if you drive like an idiot, the body panels
will break like eggshells when you crash. That's where the zip ties come in.
I'm sick and tired of all the people making chinabikes out to be worse than they are. Many a "junk" 139qmb is just in need of severe valve adjustment and some new roller weights. Those are the top 2 most common "problems" I've seen on them, and both are also commonly known as "routine maintenance". The rest of them need rebuilt because the moron owner didn't change the oil, and took out the bearings.
There are design problems occasionally, such as the completely overkill disk brakes on some of them that appear to be sourced from a full size motorcycle... My chinabike will lock up the front tire at almost any speed, but only if you slam on the front brake like a complete moron. That seems easy enough to work around... Don't drive like a moron, and don't loan your bike (cheapchina or otherwise) to any morons. Problem solved.
Also, like Tru wrote whilst I was penning my response, don't expect 100,000 miles out of the thing. They are not "junk" but you get what you pay for in the long run.
