By freeswimming at 2011-09-19
fastplastic wrote:Fail you seem to not have forget the past threads (spreetards red spree) and second you need to have a gps verf. run the stock spedo. is not very accurate..... but yes sprees can even go over 40 with a stock jug your behind the times man.....
fastplastic wrote:o just one more thing there are many reasons why ppl do engine swaps.... pretty sure no does it so they can go 3 or 4 more mph faster then a stock spree....
fastplastic wrote:p.s. big bore kits dont make you go faster to begin with its about the rpms you turn and your gear ratio.......
SuprasNsprees wrote:fastplastic wrote:Fail you seem to not have forget the past threads (spreetards red spree) and second you need to have a gps verf. run the stock spedo. is not very accurate..... but yes sprees can even go over 40 with a stock jug your behind the times man.....fastplastic wrote:o just one more thing there are many reasons why ppl do engine swaps.... pretty sure no does it so they can go 3 or 4 more mph faster then a stock spree....fastplastic wrote:p.s. big bore kits dont make you go faster to begin with its about the rpms you turn and your gear ratio.......
it took you 3 back-to-back posts in 1 thread, to try to make the OP look stupid ? rather than giving someone a hand for doing the work themselves , AND having results ?
Man you must be related to bear![]()
Maybe you should just stick with your other forms![]()
you're the kind of troll i ban, from the sites i moderate
mopro logan wrote:Man don't listen to suprasnsprees ...you are doing good things. There will always be haters.
