Hi
I have an NQ50/w 48bbk, gears and 21mm intake/carb kit. the belt is slipping, it is a new belt and you can see where it is polishing the pully. if you just grab the belt and pull the sides together it pulls into the sprung pully pretty easily so I figure I need a new one of the big main spring behind the driven pully. only problem is I cant see any and I also don't know if there are any off other bikes that fit. I did check the microfiche for this bike and the spring has a number, but it doesn't have a corresponding order code. anyone know where I can get one of these? or know of any off of other bikes that will fit?
thank you, Tim
Driven face pully spring
Re: Driven face pully spring
ok, so the microfiche that I looked at only has a corresponding code for the particular part IF they stock it, which they don't. but yeh still doesnt help me
Is this a Honda belt or something else?
The belt, 23100-GK8-870, its all years of the Spree and the SB50 versions of the Elite.
FYI, the lower the belt rides the slower you will be.
the belt is a stock one from honda, i would just ring honda about the spring, but they're slow and expensive. not that price is a problem, I just dont mind waiting for one off the net cause it would probably be here faster than honda could get one.
Are you sure you got the front pulley reassembled properly?
Yes, definitely.
- swimmingfree
a photo of it wood be nice .
with all the money you put in the motor what did you do to the pull ???
what is your to speed???
A photo? why? I'm not looking for advise on how to fix my bike, i just want to know where to get a spring and if any others fit. theres info on my build elsewhere in the forum as well as photos.
