oil pump plug oil tank
jokim00
Post by jokim00 »
Hello,
I couldn't find thiz through the search but I wanted to ask if it was alright to remove the oil tank as long as you plugged the hole where the oil pump once was.
I know that we have to maintain crank case pressure and would therefore require a plug if you arenot using the oil tank.
I just wasn't sure about removing the tank itself.
If that were possible, then I would use that small storage space for something else.
Thanks a lot.
Red 1986 Spree
Mystic
Re: oil pump plug oil tank
Post by Mystic »
yea you can remove it and plug the hole, vt cycles sells them for 10 bucks or you can make one out of spare change :D some have even suggested grinding hte teeth off the pump gear so that it doesnt engage the crank and bolt it back in
jokim00
Post by jokim00 »
sounds good sounds good
thanks mystic
Also,
I don't know how many people will be reading this thread but what do people do to premix?
As in, the fuel is small so I figured I could carry a 2.5 L jug of premix and just constantly premix and fill up but I'm wondering how everyone else does it.
Red 1986 Spree
Mystic
Post by Mystic »
For now I carry a 1 gallon red gas jug in my rear basket premixed 32:1 and a bottle of oil in case i have to stop and fill up :D
jokim00
Post by jokim00 »
awesome
also I totally forgot to ask this but, if you dont use the oil tank anymore, then does getting rid of the oil line sensor get rid of the oil light?
Ok, my wording is weird. Basically, would I have to worry about the oil light ever coming on if I plug the crank and get rid of the oil tank?
I'm guessing not but I don't want to cause weird problems.
Thanks always
Red 1986 Spree
808BMW
Post by 808BMW »
My oil light is always on, you could probably wire it up (either ground it out or connect the wires probably) to turn off.
As far as premixing, I just carry oil. When I put gas, I just watch how much I put in, and add accordingly. 0.5gallons = 2 oz, 0.75gal = 3 oz.
evilone
Post by evilone »
I carry 2 travel size mouthwash bottles. They are filled to equal 32:1 for .75 gallons.
Add oil and .75 gallons and go.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
jokim00
Post by jokim00 »
808BMW wrote:My oil light is always on, you could probably wire it up (either ground it out or connect the wires probably) to turn off.
I guess it doesnt really matter if the light is on or off because you know that that tank is not being used haha.
As for your premix method, you shut off the petcock before fill up the tank right?
Is it harder to mix in the tank?
Red 1986 Spree
Post by swimmingfree »
oil then gas the gas will mix it for you ..
if you do it just before you put in the gas why shut off the petcock???
your light if you unplug the sensor is the light on if so .. you taped them together they wood be off or take out the light bulb..
Mystic
Post by Mystic »
if you unplug the sensor and remove the tank the light will not come on if it does you may have a malfunction lol i carry a big thing of lucas 2 stroke that has measurements on the side sometimes its not 100 percent exact if i happen to only get a half gallon or whatnot so i try to get even increments. they have a syringe at walmart that you use to measure 2 stroke oil for around 4 bucks :D just saw it the other day
808BMW
Post by 808BMW »
My petcock (and most I've seen) are vacuum operated, no need to turn it off. Some of my friends put oil first and then gas, but I don't really get enough pressure from the pump to feel safe doing that.
I put gas, add oil, then rock my bike back and forth for about 2 minutes. After a while, you won't notice the funny looks while you stand there dancing with your moped, I call it the gas dance.
jokim00
Post by jokim00 »
LOL 808BMW
gas dance hahaha
I just pictured myself doing it.
Btw, youre talking about the spree right?
I was looking to see how to shut off the petcock but I dont know.
So then..it is safe to add gas then oil and to rock it for the spree?
Red 1986 Spree
Mystic
Post by Mystic »
why would you want to remove it on the spree??? unless you have modified the engine the stock pump mixes enough oil without having to worry about premixing
jokim00
Post by jokim00 »
Oh its because im installing taz's parts.
Red 1986 Spree
Mystic
Post by Mystic »
ohhh ok yea pull the pump lol
