Engine swap
bartle90
Engine swap
Post by bartle90 »
Hi all,
I was wondering if it is possible to put an af16e engine from a 98 elite on an 89 sb50 frame. If so how do I do it?
Thanks
PimpinSpree
Re: Engine swap
Post by PimpinSpree »
Not sure what's involved with that model. But it should be pretty easy
Re: Engine swap
viewtopic.php?f=16&t=13690
Use a 1980 honda express shock instead of welding an extension on to the elite e shock.
da808nanospeed
Re: Engine swap
Post by da808nanospeed »
bartle90 wrote:Hi all,
Thanks
yes, I done it before, is not too hard, u just need to use the af16 engine mount and cut it to fit onto the sb50 frame. for the shock mount, u can use one of the sa50 front shock control arm to attach shock into the stock sb50 location. if not, u can either weld a shock bracket on the frame or mount the shock at the ignitior mount hole and relocate the ignitor. but of course is abit getto
2003 Yamaha R1 998cc SOLD
1997 Honda Elite S 72cc SOLD
2007 SYM DD50 72CC X2
Goped sport 29cc
