1984 spree with 31 miles on it
cookiemonster131
- BMX
okay i bought an 84 spree with 31 miles on it. stuck a NOS tank on it and rebuilt the carb and new petcock. got it running like a top straight to 28 mph BUT after 1/2 mile or so it dies out. if i start it in the shop and let it idle for 2-3 minutes it dies out. sometimes it will fire right back up but most times not. gotta let it sit for 1 minute or 2 and it starts right bacvk up. petcock is new and fuel line and vacuum line are new. got any ideas?
cookiemonster131
- BMX
Re: 1984 spree with 31 miles on it
oh yeah new battery and new air filter also
- mopro logan
Sounds like the carb is not filling with gas I would check the float level
cookiemonster131
- BMX
thats what i thought also but i thought these floats were non adjustable since they are plastic...?
cookiemonster131
- BMX
i was wondering if the carb bystarter was acting up?
Disconnect the wires to it and try that. I did with my Gyro which had the same symptoms and it started and ran.cookiemonster131 wrote:i was wondering if the carb bystarter was acting up?
cookiemonster131
- BMX
First off if it ran that long it is not the bystarter. It would more likely be the vent in the gas cap. Loose the cap and run the scooter again and see what happens. Again the students trying to be teachers.
cookiemonster131
- BMX
Tried the gas cap already didn't fix it.
- swimmingfree
petcock is it new or new to you??
what kind of flow of gas are you getting ???
is the screen in the tank clog??
if the float gets stuck or the nettle is stuck this may happen and you will running out of gas ???
i no you clean the carb and its wright ??
we all have done it.. dum things
cookiemonster131
- BMX
Tank is new old stock, petcock is brand new as of last night. The flow out the gas line is pretty solid and consistent. As for the internals I felt certain it was clean but I guess I will start there when I take it back apart.
- swimmingfree
one other thing you may look at is the vac line to petcock ..you may
want to try this and shood let you no the gas in the carb and if you running out.
By freeswimming at 2011-09-30
Sorry Bear, but it did resolve my running issue on the Gyro. Although I had more issues than that and Mouse ended up replacing the carb on it and that fixed everything.
- SuprasNsprees
'80 Puch Magnum MKII
'78 PA50 Hobbit
'78 PA50 Hobbit
Hey, your motor/carb looks identical to mine!swimmingfree wrote:one other thing you may look at is the vac line to petcock ..you may
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
