Sym dd w/ hona dio engine i need help please!
Mystic
Re: Sym dd w/ hona dio engine i need help please!
Post by Mystic »
I am not for sure but I have been thinking of ordering one myself. they have a higher tension than the stock ones and produce a stronger spark for better fuel combustion so you really dont need one unless your compression is high like race bikes
jacob789
Post by jacob789 »
ok thanks well if u get one tell me how it is. also would a keli variator give me more top end than buying a ct intake manifold, 21mm OKO carb and 48mm air filter?
Petrock's 1984 Spree
Post by Petrock's 1984 Spree »
jacob789 wrote:ok thanks well if u get one tell me how it is. also would a keli variator give me more top end than buying a ct intake manifold, 21mm OKO carb and 48mm air filter?
On average aftermarket variators give you a 5+ mph increase. Uping the carb size can net you a higher top speed but it will not be as big a gain as swapping the variator.
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
Mystic
Post by Mystic »
definately work on the variator, if nothing but getting a SEF ramp and some different roller weights. but if you are going to do it might as well get the whole thing and do it right, you can get a variator with ramp and weights from autotech335 on ebay for around 30 and they sell the 21mm carb kit and just about all the stuff you need like taller gears and bore kits but the shipping is at least 25 from taiwan, or scooter assassins sales a vari with ramp and a 24mm carb kit with free shipping from taiwan. cheaper than the high end stuff like polini and mallossi but if done right and hte proper care taken then the parts perform just as good. ALL my performance parts i got from taiwan except the zx exhaust...don't know if it has any better output but I know its not restricted :D
jacob789
Post by jacob789 »
ok thankyou. i already have new rollers that came with the technigas exhaust. whats an SEF ramp?
Mystic
Post by Mystic »
it is an aftermarket ramp plate that has better angles than the stock ramp allowing hte rollers to move farther back so your belt can ride farther up on the drive face. look on Trafficjamz for sale thread he has one for sale for 10 or 15 dollars
jacob789
Post by jacob789 »
ill probably leave that for now, thanks anyway tho. can i ask everyone to rate the sym dd 50 out of 10 or just give me your opinions on it in general? thanks
The SEF ramp plate is one of the easiest performance mods you can do.
Or if you want to you can swap out the entire variator. You already have a big bore on it and i'm assuming you did that install yourself.
Installing a new variator is a heck of a lot eaiser and will increase your performance throughout the throttle range, normally tacking another another 5mph or better to your top speed.
I just dont want you to shy away from it because it sounds like the tough mod to do :2thumbs:
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
jacob789
Post by jacob789 »
i didnt do any of it myself lol, i take it to a garage. to tell u the truth i dont really have a clue how to fit most parts and yh ill probly get the keli variator.
what would u rate the sym dd out of 10?
thanks
jacob789
Post by jacob789 »
ok so i got the gear-up kit fitted now and i think it goes about 60mph, im not sure yet so ill have to clarify that. so im happy with it now and am gonna leave it how it is apart from getting new tyres.
thanks everyone for your help
jacob789
Post by jacob789 »
and could someone send me a link to where i can buy this scorpion exhaust please, id like to have a look thanks
jacob789
Post by jacob789 »
pictures
the gap on the foot bit is where i came off before along with the bit of plastic that went there
i had my front indicators moved to those eye bits on both sides of the front
i had my seat re-leathered in red because the old one had a rip. i also re-sprayed the whole thing in matt black
jacob789
Post by jacob789 »
more pics
carb, airbox and crankcase
my tecnigas next R sports exhaust, a bit rusty and scratched from when i fell off
sum-azn-kid
Post by sum-azn-kid »
do you knw wat gear ratio you up gears are? btw this exhaust would be better.
http://cgi.ebay.com/ebaymotors/Honda-El ... 25624cc359
zuma 125-sold
Ninja 250r-totaled
jacob789
Post by jacob789 »
i know but i already have this one now and that ones well expensive plus it says it fits 1994-2001 dios and mines 2004. is this exhaust good? http://www.ebay.co.uk/itm/Dio-ZX-Tact-E ... 2a0782b95b
and i dont know what the gear ratio is, how do you work it out? all i n know is the teeth are 16x42
