Superman -vs- Kryptonite 125cc stroker battle (new videos)
Re: Superman -vs- Kryptonite 125cc stroker battle (new vide
ottoman wrote:Actually the 100lbs = 1/10th has been a std rule of thumb in car 1/4 mile drag racing since I can remember.
Using Supermans example were removing 100lbs lowered his et by one second makes it look like 10LBs = 1/10th on a scooter.. in the 1/8 mile that is.
These are just general rules.
Traffic.. yea I think on our last day at the strip our best was 9.4 @ 67.5 MPH with a 190 lb rider and 15.8 at 77 in the 1/4 mile. Wish I could lower the gear some more but were stuck with only a few gearing options. Probably end up putting the nitrous back on to take advantage of the gearing.
That is an impressive time. My friend with a 72cc jog just can't seem to go fast......what is the secret to making the minirelli fly?
ottoman
Post by ottoman »
No secret it takes $$$ :lol:
But really there are so many high end parts available for the minerelli based scooter he should be able to go fast.
I just sent my slightly used 77cc kit, crank and pipe to Tru for his latest build... if you would have said something sooner I would have made him a killer deal on it... once Darin mentioned he was looking.. well I know he will make me proud with it :2thumbs:
If you want have him PM me with his setup, maybe I can help.
He has a 96 jog
The crank is stock but it is a japan crank from that year, i think. :confused:
he has a 72cc polini corsa, yasuni pipe, vforce intake and cf reeds, 21 and 24mm oko carbs, polini variator.
he is willing to spend the $$$ but I don't know what to tell him to buy.
He wants to go like 9 to 10 seconds in the 1/8th does he need an aftermarket crank?
tru72
Post by tru72 »
Traffic that set up properly ported and tuned can go mid 10s in the 1/8 with a 125 lb rider.. I built a bike here with the same bore.
That pipe not be the best match for that bore , im not sure which he got. He should use the polini pipe, works great with their stuff.
building and tuning a minarelli style motor cant be compared to a dio at all. Its a totally different set up with the weights and springs.
ou really need to do the homework and buy stuff that matches the power band and rpms.
Its not like a dio and just put anything on there and it goes LOL!!
Ottoman yes you know i will put that to good use for sure, did some studying today at the bore and can see some areas that can be cleaned up and changed.
Ill keep you posted as usual.. ;)
aloha
D
atomicareprise
Post by atomicareprise »
Trafficjamz wrote:
sum-azn-kid wrote:are you running the big mani?
Big mani and vforce CF reeds stage 6 Velocity stack 30mm oko carb
wow you actually fitted the vf3...
can you tell me how u convert them to fit in that manifold..
vf3 is by far the best reed valve i know..kinda pricey too and that sucks :smile:
btw..u think u'll get more power if u use bull pipe for ur set up..
PINOY SCOOTERISTA!!!
atomicareprise
the fastest jog in our country has 2fast kit on it..
all italian parts..tuned by overrev team
in our country we usually ran on 400m...
i think it runs no higher than 13sec in 400m..
its a 77cc jog :smile:
The reeds just fit that manifold.
Getting that manifold to fit takes a little modification :wink:
What is the bull pipe?
I just got a scorpion pipe. for my setup.
atomicareprise
do you ported the manifold?
we call the scorpion pipe in our country bull pipe...
i don't see scorpion pipe model in our country..
what we have here are lm pipe and cmr and v8...
most are taiwan made and kinda pricey :smile:
so we just go for custom pipe...
btw what crankshaft do u use and what the stroke?
do you ported the manifold? I did smooth out some rough edges
btw what crankshaft do u use and what the stroke? 55mm bore on a 52.6mm crank = 125cc
atomicareprise
did u ever tried to run ur monster in 400m?
atomicareprise wrote:did u ever tried to run ur monster in 400m?
Our local dragstrip is only an 1/8th mile (201 meters) Those are the only "official times"
I would guess that 400m would take about 15 - 16 seconds.
atomicareprise
oh i see...
SpreeMadness520
Post by SpreeMadness520 »
Post some pics of the scorpion :rock:
130cc Stroker
1984 Porsche 944
1965 Vespa
atomicareprise
scorpion pipe how many cuts do they have in them...
i think i'll be going for that design..replica... :smile:
tru72
Post by tru72 »
Bull pipe, GM pipe, Jad pipe all of them are some what related in designs with the scorpion.
