SE50P Variator Purchase
countmcnugget
Post by countmcnugget »
Hello,
I'm looking to deregulate my 1987 Honda Elite SE50P like a lot of other people and have researched some variators. The pollini variator looks like it comes with a ramp plate. It is more than the Keli variator but the ramp plate would be huge for me as I've had no luck locating one. I tried to order just a ramp plate off of Babbit's Online only to find out it is discontinued after waiting for a week. Any assistance on whether the Pollini variator would be a good buy for the 1987 Elite SE50P? Thanks in advance for any guidance! This forum has been amazing for a noob like me!
1987 Elite SE50P
Re: SE50P Variator Purchase
The Polini for SE/05 should come with a pulley boss that replaces your stock one. It is an excellent choice, possibly the best one out there. There are cheaper choices, but none much/any better.
countmcnugget
Thanks so much, I found this bad boy online http://www.scootershop.com/catalog/prod ... ts_id=2375
You think this would be a decent price?
Thanks again for your help!
1987 Elite SE50P
evilone
Post by evilone »
countmcnugget wrote:You think this would be a decent price?
It's hard to find them any cheaper.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
turtle13
Post by turtle13 »
Keep in mind that you will:
A: have to use your stock drive boss from your stock variator for it to fit.
B: you will very possibly have to dremel out the casework by the starter to allow it to fit. Not hard, just takes a little time and patience.
'62 125cc Honda cub
countmcnugget
Hehe got a polini ordered and a pipe can't wait!
Thanks for all the advice now to check out my carb i'm pretty sure it is an 82 and sounds like i should get an 85.
1987 Elite SE50P
countmcnugget
The Pollini rollers I got with the variator are I believe 6.9 or 6.3 grams is that okay to use in the 1987 SE50P or should I purchase some heavier rollers?
Thanks in advance for any advice!
1987 Elite SE50P
IF the stock rollers were 10s, then a jump down to 6.9 is huge. Changes of no more than a half-gram (3 grams total)at a time are done so you don't "overshoot" the ideal. I'd try all 9s first and see if the engine "bites" into its powerband. I fear with 6-somethings, it'll just rev to the moon and not really get down the road. Try the 6es if that's all you've got and see?
countmcnugget
Thanks wheelman tried the rollers that came with haha sounded like i was going 50 but i wasnt moving haha. Will get some 9's asap!
Thanks again.
1987 Elite SE50P
countmcnugget
So i tried the 9's and no luck my leovince sp3 came in from germany yesterday so wanted to see how she'd do. Also wanted to make sure i hadnt screwed anything else up with the variator so i put the old restricted one on and the pipe. She moved again! But i only hit about 20 mph im goin backwards haha. Picked up some 10 gram rollers today hope it helps.
1987 Elite SE50P
countmcnugget wrote:So i tried the 9's and no luck my leovince sp3 came in from germany yesterday so wanted to see how she'd do. Also wanted to make sure i hadnt screwed anything else up with the variator so i put the old restricted one on and the pipe. She moved again! But i only hit about 20 mph im goin backwards haha. Picked up some 10 gram rollers today hope it helps.
That leovince pipe has a restrictor welded in the head pipe........You need to remove it to get the most out of it. :wink:
countmcnugget
Oh shoot i didnt know that thanks trafficjamz. Do u know how difficult the process is/tools necessary? Thanks for your help. I might be faster than the neighbor kid on his 10 speed eventually haha!
Thanks again!
1987 Elite SE50P
atomicareprise
Post by atomicareprise »
buy a koso pulley...it's a taiwan made with a cheap price with a good performance...
it's way cheaper than polini..
PINOY SCOOTERISTA!!!
countmcnugget
Alright got the 10 grams in and ran it with the sp3 and pollini variator. Pulling 26 still. I am thinking the next step will be to get a new belt not sure how old the current one is, cleaning the carb which will be very interesting haha (not to mechanically handy) but i guess i gotta learn somehow and derestrict this sp3.
Wish me luck!
Any words of wisdom greatly appreciated.
1987 Elite SE50P
Post by eliteguy50 »
countmcnugget wrote:Alright got the 10 grams in and ran it with the sp3 and pollini variator. Pulling 26 still. I am thinking the next step will be to get a new belt not sure how old the current one is, cleaning the carb which will be very interesting haha (not to mechanically handy) but i guess i gotta learn somehow and derestrict this sp3.
Wish me luck!
The belt width is more important than its age. When I swapped the Polini variator with Polini weights in my stock Iowa se50, it would max out at 30mph, up from the stock 25mph.
