my new to me scooter with slight build
so i came across this 86 spree needed some work, well she runs great and i added some crf 50 dirt tires and cleaned her and added a updated front panel painted the rims and floor board i just need a right side turn signal cover who's got one
Re: my new to me scooter with slight build
Congratulations. Click on this thread and keep look'in around, you'll probably find anything you're look'in 'fo.http://www.hondaspree.net/phpBB3/viewto ... =2&t=20755 Happy trails!
DeathByFox
Did you order those tires online? If so could you provide a link? Also that spree looks great. Makes me almost wanna buy my mother in laws of her and do that exact thing.
Bright lights put me in a dance But it aint house music makes me wanna dance
i ran a 2.75x10 in the front ( normally the rear on a crf50) and i ran a 2.50x10 on the rear as there are clearance issues unless you go modding rear fender and more i believe. If i was to actually purchase them I usually run IRC kids tires on my 50's but i had these extra laying around so thats why they are on there.
New question Carb issues was running great now it does not want to go it will start and idle perfect but when giving gas it bogs and dies i can get ti go but it is not great at all.
I have cleaned the carb ten times and it seems to be an adjustment issue also before it would only run good with air filter off.
all suggestion appreciated
thanks
thanks
Have you done a compression test?
Awesome looking spree! Did you download the honda service manual or check the technical pages at: http://hondaspree.net/wiki/index.php5?title=Main_Page ? Happy Trails!
Update
Running with airfilter and cover on but will run for a half mile then bog and i have feather the throttle to get it back. It seems to be over loading with fuel. Also i had it running good but up to about 27mph but if i turned the throttle WOT it would bog so i have to leave the last little not untouched. I did get a new float since mine was not right. Also in order for it to run the air/fuel is only turned out maybe a 1/4 turn as opposed to the 1 7/8's it should be. If i start at that point no good comes from that. I have moved the neddle circlip to the bottom slot in hopes to richen the bike that is not working so i guess i will try the other way today and go from there.
thanks
thanks
That is a 1987 Spree. Looks nice too.
needle clip should be in the middle, compression test should be on your list of to do. also did you wash the filter and reoil? might want to check for an air leak, since the carb was off "10" times look there. it almost sounds to me(im not expert) it might be to rich. oh by the way nice spree!
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
