I'm going crazy. Losing spark when hitting bumps/pitch diffs
Chicago Ben
Re: I'm going crazy. Losing spark when hitting bumps/pitch d
my size 60 pilot jet came in today from scooter assassins , let everyone know what happens here...
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
1000k Polini triples
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Hey Ben, so maybe it works. Hope so bro. If not, do you have another carb to swap? Those oko's are cheap knock offs of the keihins, could it be a bad unit? I use an oko and I don't understand why there's no instructions or anything to help you, just say'in, but I had trouble getting it to work right. I don't know what's causing your trouble, but I guess I just wanted to make that suggestion. GL
Also maybe check the slide in the carb, it may be closing if the adjustment isn't touching the slide. Check slack in the throttle cable also, when you move it around does it change the idle? Just think'in out loud. Best of luck.
Chicago Ben
Just bought a "racing" coil , one of those orange ones you see on ebay. 15 bucks from Hawaii. Need this problem to end!
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
Put the new coil on, same problems. What's next? Currently running 52 pilot 125 main. Air screw half way out... Am I just grounding out somewhere really trying to remain calm with this issue. Float set to 18/19mm per oko spec, running stock float bowl again.
Ideas?
Ideas?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Change ignition switch.Chicago Ben wrote:Put the new coil on, same problems. What's next? Currently running 52 pilot 125 main. Air screw half way out... Am I just grounding out somewhere really trying to remain calm with this issue. Float set to 18/19mm per oko spec, running stock float bowl again.
Ideas?
If that don't work, change kill switch.
- Trafficjamz
is it grounding out in the cdi plug?
black/white wire touching green wire or black/white wire touching the frame somewhere?
Chicago Ben
Well guys just told traffic I pulled the trigger on a 28mm Keihin pwk. Coming from Taiwan, should be here in about 9 years. I'll check back then.
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
- Trafficjamz
is it from autotech355?Chicago Ben wrote:Well guys just told traffic I pulled the trigger on a 28mm Keihin pwk. Coming from Taiwan, should be here in about 9 years. I'll check back then.
Chicago Ben
It is some oddball seller Bazsogaborus? 100% feedback...Trafficjamz wrote:is it from autotech355?Chicago Ben wrote:Well guys just told traffic I pulled the trigger on a 28mm Keihin pwk. Coming from Taiwan, should be here in about 9 years. I'll check back then.
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
an update for anyone who cares:
Took it around the block with the new CDI...
Bike dies, spark cap hanging down off frame... *!?
Turns out, when suspension is fully loaded over bumps/etc the spark / spark cap was hitting the front most part of the rear fender plastic. Cut all that plastic out (where the fuel/vac/oil hoses used to sit)
This force was strong enough it actually bent the spark plug tip (non-electrode side) .... guess those base gaskets and 52mm BBK raised this too high ? ??
Anyway, that isn't my issue cutting out over bumps, however that was clearly a separate issue.
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
- Trafficjamz
you ever change the carb?
Chicago Ben
Still hasn't come from Thailand. Ebay woes...Trafficjamz wrote:you ever change the carb?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
carb came today - ill put it on after work - legit Keihin!
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
Problem solved! Garbage oko carb...
I am having a small issue , the new Keihin float drain keeps * fuel and the screw is all the way tightened... Might just cap it off
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
- Trafficjamz
Chicago Ben wrote:Problem solved! Garbage oko carb...
OMG finally!
wanna sell the oko 26 for cheap
