Hi all ruima cylinder crankshaft 50mm 44.1mm 24mm oko carburetor main jet 128 pilot 46, 33mm exhaust v8, a beautiful brown candles but do not go 45mph lehhet what's wrong.
Sorry for the translator understands this writing program I write I do not speak English.
Budapest, Hungary.
Thank you for your answers. Vidra
HELP
HELP
Honda dio AF-18E engine cylinder 50mm Ruima carburetor Dellorto PHBHB 28mm main200 exhaust 28mm v8 Crank 44.0mm Clutch Spring red Clutch Pad Springs white Primarygear Malossi16/32Secondargear Ruima17/42 Malossi KEVLAR Belt Pulley 8g Air Filter X2
Re: HELP
sebess├®get v├íltani meghat├írozott ├ítviteli
gy├íri fogasker├®k k├®szlet t├║l lass├║
If that fails, try translate this: Change your transmission gears, if they are the factory gears, it is too slow.
Re: HELP
Hi Malossi final drive ratios 16 * 32 secondary ruima 17 * 42
variable 6pcs 7.5g
variable 6pcs 7.5g
Re: HELP
How many gears sets did you change?
If you bought 2, you need to change 1 back to factory. Use malossi gear + stock gear, or ruima + stock gear, but do not run malossi + ruima gear.
Re: HELP
Thank you, this will be a problem.
Thank you István Vidra
Re: HELP
Hi
cylinder: ruima 50mm
crankshaft: racing teflon 44.1mm
exhaust: SYM V8
carburetor: OKO 24mm main 112 pilot 46
vario: 8g
clutch: red,white
cdi: fox racing
end transmission: malossi 16*32
top speed: 53mp/h
but it is not enough what can I do to drive faster?
picture if you need to do.
please help.
exhaust: SYM V8
vario: 8g
clutch: red,white
cdi: fox racing
top speed: 53mp/h
please help.
- swimmingfree
Re: HELP
what is your rpm at 53mph ???
Re: HELP
Hi, unfortunately I do not know the wrong speed measurement devices.
Re: HELP
Hi all I bike.but do not go more than 50mp/h have no idea what to do.
[img] http://kepfeltoltes.hu/view/111029/IMG0 ... es.hu_.jpg
http://kepfeltoltes.hu/view/111029/IMG0 ... es.hu_.jpg[/img]
Re: HELP
Hi all The problem with the engine spinning 4500rpm no more than what could be the problem.
